So I am looking to build a PC a little bit before BF3 comes out... which is still quite a few months away. I want to get an idea though since I might want to sell/part out my current PC.
For really great perf in BF3, mainly want to now what I could keep and what a complete system would look like.
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing?
Obviously gaming is the big thing. Moderate overclocking. Everything else should fall into place.
If I did everything new, ~$1000.
3) Where do you live?
Not sure when BF3 comes out... maybe CA..
Not sure what I can reuse... I need a bunch. (CPU, CPU fan, Mobo, GPU, SSD/HDD, DVD, PSU, case, mouse, keyboard, monitor)
Here is my current build:
*** LIAN LI PC-7B plus II PC case
*** PC Power and Cooling S61EPS 610W Continuous @ 40°C EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power
*** DFI LANPARTY DK P35-T2RS LGA 775 Intel P35 ATX Intel Motherboard
*** Q6600
*** Sunbeam CR-CCTF 120 mm Core-Contact Freezer CPU Cooler
*** G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000)
*** XFX PVT88PYSF4 GeForce 8800 GT 512MB 256-bit GDDR3 PCI-Ex 2.0
*** Seagate Barracuda ST3500320AS 500GB 7200 RPM SATA 3.0Gb/s
*** RAID0 2x15k RPM SCSI Ultra-320
*** SAMSUNG 22X DVD Burner Black SATA Model SH-S223F - OEM
*** Creative Sound Blaster X-Fi Titanium
6) Will you be overclocking?
Need the ability, yes. Air cooling likely.
Have a 20" widescreen now I think. Those 24" high-res ones look nice.
~Winter 2011
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Sata 6Gb/s
Arch Linux and Windows 7. Either.
*** Q6600
~Winter 2011
Sata 6Gb/s
