x_MaGiuS_x
- Dec 28, 2008
My eventual plan is to run two of the 6950s in Crossfire is there anything I overlooked? (Case, optical drives and cooling is already taken care of)
If this were your system would you use different components? I have been out of the hardware loop for a little while
Video Card - MSI TwinFrozr III 6950 2gb
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127575
Motherboard - Gigabyte GA-P67A-UD4-B3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128478
Processor - i7 2600k
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
PSU - Corsair HX850
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
Ram - GSkill Ripjaws 8gb DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
SSD - Intel 320 series 120gb
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167050
The components are sitting in my cart ready to order. I can afford them but need a push before I can hit "submit order."
Just want to be sure Im not missing out on something better for the same price or less.
Any insight would be greatly appreciated.
PSU - Corsair HX850
