CAD/CAM - Solid Edge, Mastercam, Pro E and AutoCad
700 plus tax
3) Where do you live?
Toronto Canada
CPU, MOBO,Video card, hdd, case+power supply
none
6) Will you be overclocking?
none
22''
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
SATA 6gb/s yes, but may not be within budget and raid would be nice but not necessary..
32 bit xp
So com'on and give me some options. This is really difficult as i am not sure to go AMD or intel. I was thinking a x4 (more cores the better in this application), 4gb ram (32 bit cant make use of 3gb correct). When looking at prices i find that i can get either a i5 with two core or a amd x4 955. Now i know that the i5 will be faster, but it's two extra cores for around the same price...PLUS cheaper mobo for the AMD which equals more money for video card. Ugh, i need a fine balance...
Motherboard i have no clue. Will a cheap Asus rock work or will i have issues with stability? Like i stated 6gb/s sata would be very nice as it should help shorten load times..
Intel wise, i know nothing about mobo or chipsets...help me out on that one =P
Hard drive, doesn't really matter too much BUT i am thinking if i can fit in just one 60gb solid state this can speed up things and have a secondary 1tb...i know that is not budget friendly BUT factor in that the secondary is NOT needed. ALSO, i have concerns that solid state HDD do not like AMD systems? Is this correct?
Video card, oh boy. The real question is what will perform better in CAD environment, a ATI FirePro V4800 or a ATI 6850? I have looked for reviews and found nothing to compare. I am going to ask this in the video card section.
Case/PSU - Antec Sonata 3...but will the 500 watt be enough juice?
Now i would prefer stores i can drive to and pick up the parts as this is needed ASAP and is for work, not personal. Online works too, just have to consider shipping i guess.
Thanks!
700 plus tax
Toronto Canada
none
none
22''
ASAP
32 bit xp
Thanks!
