excellsior
- Jun 10, 2006
Hey guys, I'm looking to spend 500 on a budget build to run War Hammer Online.
I'm looking for dual core 2.5 or more overclocked.
2 gigs of ram
Windows Vista
Best video card that falls into budget without taking out too much from my mobo/cpu
CD drive
I plan to reuse my Xtreme music soundcard and keyboard/mouse/case/etc.
I have a Nec 20wmgx2 SIPS monitor as well.
If you guys think I should squeeze in another 50-100 I'm all for hearing it out. Please let me know what's the best deals you would recommend.
A quick look on newegg gives me this:
160$ 2.6 intel core2 duo (can probably oc easily to 3.0)
100$ elitegroup mobo
50$ psu (or i can use my old antec one that came with the case.. need to check watts)
160$ 8800gtx 640mb pci 2.0 x16
80$ ddr2 800 ocz 2 gigs
30$ dvd burner
100$ vista home 64bit
PC SYSTEM REQUIREMENTS
For Windows XP
* 2.5 GHz P4 (single core) processor or equivalent
* 1 Gigabyte RAM
* A 128 MB Video Card, with support for Pixel Shader 2.0
* At least 15 GB of hard drive space
For Windows VISTA
* 2.5 GHz P4 processor or equivalent
* 2 Gigabyte RAM
Supported Video Cards
ATI Radeon series
* 9500, 9600, 9800
* X300, X600, X700, X800, X850
* X1300, X1600, X1800, X1900, X1950
* 2400, 2600, 2900,
* 3650, 3850, 3870
* 4850, 4870
NVIDIA GeForce series
* FX 5900, FX 5950
* 6600, 6800,
* 7600, 7800, 7900, 7950
* 8400, 8500, 8600, 8800
* 9400, 9500, 9600, 9800
* GTX 260, GTX 280
Intel Extreme Graphics
# GMA X4500
2 gigs of ram
Windows Vista
CD drive
30$ dvd burner
For Windows XP
* 1 Gigabyte RAM
For Windows VISTA
* 2 Gigabyte RAM
ATI Radeon series
* 9500, 9600, 9800
* 2400, 2600, 2900,
* 3650, 3850, 3870
* 4850, 4870
* FX 5900, FX 5950
* 6600, 6800,
* GTX 260, GTX 280
# GMA X4500
