The main reason I'm looking to upgrade is that my current system can't handle the multi-tasking I do. I often have photoshop, matlab, lots of browser windows, excel, and some word documents going at once and my current system isn't cutting it. I have an E6750 at stock on a DS3 with an 8800GT and 2 gigs of RAM with a Corsair 550VX. As far as gaming, I plan to play both Skyrim and Diablo 3 (1920x1080 likely), but I won't be able to play them until late december. I'm trying to decide between 3 options as far as upgrading goes.
1. Keep current system but buy 2 more gigs of DDR2 for cheap and overclock the 6750. Should allow me more multi-tasking room and then I can upgrade later when I have time to play Skyrim and Diablo 3.
2. Get a 2500K plus an inexpensive motherboard combo at Microcenter along with 8 gigs of cheap DDR3 and use my 8800GT until I can play Skyrim, at which point I can get a new video card.
3. Go for the above except with a new video card. I'm not too sure about which one I'd want. Would like to spend around 200$ for the video card, but I have a hard time justifying this right now when I won't really be playing any games for the next 4 months.
I would like to reuse my 550VX with any upgrade, so if that's not possible I'll probably just wait a bit longer until I really really need an upgrade. I have no problems with overclocking and will be using 64 bit Windows 7. I'd like to keep the price as low as possible, buying at the max performance/price ratio. Basically, I'm wondering whether it's worth waiting for video card updates/price drops over the next 4 months and what type of card will be necessary for my gaming needs.
Thanks!
Thanks!
