My PSU life came to an abrupt end 2 days ago makes me realize that it's desirable to have another system. Only this one will be use for programming only as I spend a lot of time writing program for assignments and for fun. This build will orient toward CPU speed.
Programming mainly and web browsing
£400
UK
Case, CPU, Mobo, RAM, HD.
None
6) Will you be overclocking?
Nope
7) 7) What is the max resolution of your monitor? What size is it?
I got 2x23inch 1920 x 1080 spare and I want to use them both.
In a week or so.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
None in particular as it's only for programming, having faster CPU is desirable for compiling large projects and lot of files.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Will be using Linux 64 bits.
I'm thinking:
4GB (2x2GB) Corsair DDR3 XMS3 Classic, PC3-10666 (1333)
AMD Phenom II X4 955
Gigabyte GA-880GM-USB3, AMD 880G
500W PSU, Coolermaster Silent Pro M RS-500-AMBA-D3
Total: £248
Idk about case yet, but these are available on site: Lian Li PC-Q07B (£45) or Silverstone SG05B Mini-ITX but with 300W PSU (£84)... I want to keep the overall cost as low as possible. So if the Q07B can house these components, I will get it.
Already have a spare AMD 4850 graphic card. I can re-use it to make use of dual screen.
Any thoughts?
If you list the parts that I may need to change then I will look for best price on the web.
Ops, I forgot HD, I will go for a 500GB Samsung spin point if it's still the best bang for the buck? I think it's about £40.
£400
UK
None
Nope
In a week or so.
I'm thinking:
Total: £248
Any thoughts?
