Budget overclocking rig (Due April-May)
andrus
My goal is to get 3.0ghz out of an E4300 while staying on a pretty tight budget. I'll be buying after the Intel price cuts and after the 8600's come out.
Intel Core 2 Duo E4300 Allendale 1.8GHz 2M shared L2 Cache LGA 775 Processor - Retail $110
MSI P6N SLI-FI LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard - Retail $113
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-2GBNQ - Retail $145
Seagate Barracuda 7200.10 (Perpendicular Recording) ST3250620AS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM $75
COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel, SECC ATX Mid Tower Computer Case - Retail $50
FSP Group (Fortron Source) AX450-PN, 12cm FAN, version 2.2, 2 SATA, PCI Express, 450W Power Supply - Retail $50
LITE-ON 16X DVD±R DVD Burner Black SATA Model SH-16A7S-05 - OEM $30
nVidia 8600GTS 256mb ~$180-$200
Total ~$750 before tax, shipping
My main concern is the CPU cooling, mobo, PSU, and the RAM. I don't really want to spend $40 on a HSF but I don't know if I'll be able to get 3.0ghz out of stock cooling.. I've heard good things about the mobo but the DS3 is one of the most popular ones for just $10 more so I don't know if I should go for it instead. I've also heard good things about this PSU but I need some reassurance that it'll keep my system stable after that overclock. And will these G.Skills (red version) hold up my overclock?
Also this is my first build/attempt at overclocking so if any parts are pretty complicated to use, I would appreciate a warning.
I'm not familiar with how well that board overclocks. Trust me, you'll be kicking yourself if you go with a component because its its 10$ cheaper. (look at my mobo, I got the non sli, crappy version)
you're spending 750$. whats another 40 for good cooling?
also, i'd try to get at least a 500w power supply. Not that its a big deal for that rig, but certainly more future proof. I think you can get the nuuvo 520 for like 65
I used to have that mentality... but then I realized that I would say that for pretty much every part and end up in the mid 1000's :p .. I don't know.. I guess I'll just have to bite the bullet.
Which brand is nuuvo? Or is nuuvo a brand? Anyways I doubt I'll upgrade any of the parts until I get a whole new computer and by then, I would rather just get a new PSU because I wouldn't trust a new system with a budget 2 year old PSU..
And yeah, I'll guess I'll just get the DS3..
Perfect timing... as intel price cuts are due April 22nd. http://www.guru3d.com/newsitem.php?id=5086
Change to the Centurion 534 and an XClio Goodpower 500W instead. The 534 uses all 120mm fans, so its more quiet, and the goodpower is a solid channelwell unit thats slightly better than that budget AX model FSP, for the same amount of money. If you want better quality, the XClio 460W Stablepower is Enhance built (better than both of the previously mentioned PSUs), or go for an Enhance 5150GH 500W from eWiz.com. I think thrawn86 was referring to the Sunbeamtech Nuuo 550 Watt Modular PSU, that used to be $60 at the egg, but its now hard to find at that price. If you want modular, the Antec SP2.0 500W is nice, but is overpriced, imo (I actually own two of 'em, but got them for dirt cheap AR).
$30 - Cooler Master Centurion 534 RC-534-KWN1 Black Steel ATX Mid Tower w/ Side Window
$52 - XClio Goodpower 500W ATX 500W
$70 - Enhance ENP-5150GH 500W 80+ Efficiency
3Ghz from an E4300? thats their avg OC, so it should be easy. Now, lets do some math... 9*333=3.0Ghz... so you really only need DDR2-667, unless you plan on upgrading that CPU at the end of the year and will be needing 400+Mhz capable ram. Though, that G.Skill ram can reach around 430-450Mhz... but the E4300 can't reach much higher than 3.2Ghz (9*355). You might want to get a better cooler, like the AC Freezer 7 Pro for $20, or the Scythe Ninja Plus Rev.B for $40.
I think I'll go for the 460 StablePower. Don't think I need 500W (since I likely won't upgrade at all except for maybe a sound card) and better quality for the same price is always good :).
I'll also go for the 534 but not that version with the side window.. I read that the front fan gets virtually no airflow because of the sideways HD cage. The version without the window has the front fan on the side so it doesn't have that problem.
I realize that about the RAM but I don't know which DDR2 667 I would get.. I see G.Skill 5-5-5-15 for $115 but they don't have heatspreaders (don't know how much that affects it.) The other G.Skills are more expensive then the now $140 DDR2 800s (damn those things were like $165 just a couple weeks ago IRC.)
Where can I get an AC Freezer 7 Pro for $20? I think I'll go with that one if it's $20. Newegg has it for $40.
Modified build:
GIGABYTE GA-965P-DS3 LGA 775 Intel P965 Express ATX Intel Motherboard - Retail $190
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-2GBNQ - Retail $140
COOLER MASTER Centurion 534 RC-534-KKN2-GP Black Aluminum & Mesh bezel / SECC Chassis ATX Mid Tower Computer Case - Retail $50
XCLIO STABLEPOWER 460W ATX 460W Power Supply - Retail $50
And I also notice that the DS3 is $5 cheaper now :)
The MSRP of the AC F7 pro is $20, but due to limited availability, everyone is marking them up. These places have them in stock, but you have to figure out who has the best shipping...
$24 - Arctic Cooling Freezer 7 Pro CPU HSF @ .us.ncix.com
$25 - Arctic Cooling Freezer 7 Pro CPU HSF @ xoxide.com
$22 - Arctic Cooling Freezer 7 Pro CPU HSF @ directron.com
$22 - Arctic Cooling Freezer 7 Pro CPU HSF @ svc.com
$19 - Arctic Cooling Freezer 7 Pro CPU HSF @ eWiz.com
If the price reaches $35, you might as well go for the Scythe Ninja Plus for $40 from the egg isntead.
$40 - Scythe SCNJ-1100P Ninja Plus Rev.B 120mm CPU HSF
I suggest the Sunbeam NUUO over your original psu, or the XClio goodpower. It's just.. More.
I cant find the Sunbeam NUUO 550W anywhere... Well, ok, xoxide has it for like $80+$8 shipping. But the egg used to have it for $60 :(
The Arctic Freezer 7 PRO does not contain the C2Ds on their list of compatability.
It only has the Pentiums on their.
Go with the Ninja.
...bruins, that's sort of a ridiculous statement to make. It's the same socket type, and if they confirmed it to work with the Pentium Ds, which output between 105 and 130W at stock speeds, I would think it would work with the Core 2 Duos, the fastest of which put out 65W max..so the E4300 probably does 50 or lower. Oh, and I personally think it's worth the extra $75 to have RAID0 and 250GB more storage space, but I wouldn't recommend that if you don't have a backup strategy / important data.
http://www.silentpcreview.com/article285-page6.html
Nicely put. But also, a quick check on the Arctic cooling website will reveal:
http://www.arctic-cooling.com/cpu2.php?idx=79
Freezer 7 Pro
Application:
All Intel Celeron (Socket 775)
All Intel Pentium 4 (Socket 775)
All Intel Pentium D
All Intel Core 2 Duo
Core 2 Extreme Quad
Recommended Retail Price (excl. VAT):
34 USD / 28 EUR
Wait, the MSRP is $20? sunuvabitch. I paid $30 for it a few months ago. Crap!
My bad, Danny. It used to be $20 at the egg, but is now $40 (dropping from $60... at least it didnt stay tripled, lol). So actually, you got it for under MSRP :D
