Budget OC system - 3600 or e4300
RedCt
Would you say an E4300 or a Brisbane x2 3600 is the best for a budget OC system? I'm also looking for a solid upgrade path in the future when I can get a bit more money.
Depends on your budget.
My budget is around $00 (so it's not really that budget)
I'm looking for a good, solid, OC-able build with a good upgrade path (like I said in the original post). I'm mostly going to be using it for a light gaming machine (WoW, some older games, maybe some fancier DX10 stuff when I have enough upgrade money) the occasional Photoshop, and bits of everyday stuff. So basically, an home/office rig with a little bit of light gaming on the side.
With that budget, you could easily get a nice E6300/6400 build together without skimping on too much.
That would seem to be to be the best path for future upgradability.
Edit: I totally missed the OC part (dumb). Still doesn't change my vote for C2D, just go with the E4300 :p
Is this budget for new build from the ground up? Like new case, new monitor, new OS, etc?
Yikes! Did type $900? :eek: I meant 800 - should fix that.
Yes, it is from the ground up (but I already have a monitor).
Intel Core 2 Duo E4300 - $162.99
GIGABYTE GA-965P-S3 Socket T (LGA 775) Intel P965 Express - $107.99
G.Skill F2-6400CL5S-1GBNQ 1GB (2x 512MB) DDR2 800 RAM - $89.99
eVGA 256-P2-N615-TX GeForce 7600GT 256MB PCI-Express - $109.99
Seagate Barracuda 7200.9 160GB 7200RPM SATA 3.0Gb/s - $57.99
NEC Black DVD Burner - $29.99
XClio 450BL ATX 450W Power Supply - $37.99
COOLER MASTER Centurion 5 ATX Mid-Tower - $49.99
Windows Vista Home Premium - $119.99
Total: $767.92 plus tax and shipping
You should be able to OC this system pretty nicely. If you live in California however, with tax and shipping added, it comes out to about $870 or so.
Better, cheaper case:
$30 - Cooler Master RC-534-KWN1 Black Centurion Steel Mid Tower ATX Case w/ Side Window
Swap the case you suggested with the one enginurd suggested, and it's only gonna be 20 over, which is easily worth the difference.
H'e'd be over budget by $50 but its a worthy upgrade. But wouldn't that limit his OC capability a bit? Because that ram you suggested (DDR2 667) is slower than the one I selected (DDR2 800). Just wondering.
Well, with the E4300 averaging 3.0Ghz, DDR2-667 should be perfect, since 9*333=3.0Ghz. I'm sure those sticks could even OC just a little for the extra push to 3.2Ghz, if you're lucky with the CPU (9*356=3.2Ghz).
