Budget HTPC
js09
I am forced to build an HTPC because either my wireless-n router, plex, or both, is UNABLE to stream large mkv's wirelessly to my TV without buffering every 60 seconds. So this is my budget build:
This is what I am looking at now without your help:
case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811163174
cpu: http://www.amazon.com/Intel-Pentium-Dual-Core-Processor-Cache/dp/B005LLBBSS
mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813130654
psu (anything *<$40) http://www.newegg.com/Product/Product.aspx?Item=N82E16817171046
ram: 4gb enough?
keyboard (obvious choice?) http://www.newegg.com/Product/Product.aspx?Item=N82E16823126264
ssd: not needed unless there is a great value option
flawless playing 10-20GB 1080p mkv's with PLEX or VLC
will be played on a 1080p 55" LG 3D SmartTV
$300 out the door. i do have shoprunner for newegg
US, Virginia
cpu, ram, mobo, case, psu, keyboard
sata hard drives for storage, cords (hdmi)
6) Will you be overclocking?
if necessary
now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
probably HDMI to connect MOBO to receiver, USB 3.0 (preferred)
i have windows 7 and 8 64-bit
Just checking.. will you be going to a hard wired connection? Wireless N and high bitrate MKV streaming don't always play well.
