Budget Gaming SFF Build
ThR!LL
This is my first SFF build and I can't seem to decide whether to go i7 or Phenom. I already have a PSU which is the Corsair HX620 and I'm wanting to try not to go over $1100. I will be planning to OC and I don't know what heatsink to get.
Case: Lian Li PC-V351B
DVD Burner: Lite-On iHAS324-08
Hard Drive: Western Digital WD6401AALS
Video Card: Sapphire HD 4870 1GB
Now this is my idea for an i7 build but I'm not really confident in my choices at all.
CPU: Intel i7 920
Motherboard: DFI LANPARTY JR X58-T3H6
Memory: G.Skill 6GB DDR3 1333 (PC3 10666)
As for the AMD build I'm only sure about the processor which is the AMD Phenom II X4 955 Black Edition
If you have the budget for it, definitely Core i7.
I agree, if you can afford it, go i7. Definitely get the DDR3-1600 kit instead, though (the one King of Heroes linked to).
Honestly, your current build looks very good.
You might want to look at this memory kit. DDR3-1600 for the same price and voltage as the one you chose:
G.SKILL 6GB DDR3 1600 (PC3 12800)
I don't see a monitor on your list. Do you already have one? If so, what's the resolution?
Im using a 24" monitor. Is there a better motherboard I could pick?
The only other mATX Core i7 motherboard that I know of is this:
$250 - Asus Rampage II Gene Intel X58 mATX Motherboard
