wrxdrunkie
- Dec 23, 2007
Hi all, I am rebuilding my gaming PC, I will probably only reuse the DVD drive, OCZ powerxtreme 1000W PS, and my monitor.
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? etc. Gaming, Excel, Web Browsing, Everything.
2) What's your budget? Are tax and shipping included? My budget is between $450-$750
3) Where do you live? I live in Austin, Tx
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.Depending on advice I will need a GPU or GPUs, MB, HDD, Case
OCZ ProExtreme 1000W power supply
-DVD RW drive
-Zalman 9700 cpu cooler
6) Will you be overclocking? Yes, if recommended
7) What size monitor do you have and/or plan to have? Samsung syncmaster 2343, 23inch. 2048x1152. 40inch 1920x1080 (most of the gaming)
8) When do you plan on building/buying the PC? I plan to start buying now and build over Christmas break. Late Dec/Early January
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc. Optical out, good overclocking capability. Crossfire or SLi
10) Do you already have a legit and reusable/transferable OS key/license? Yes, Windows7
-DVD RW drive
