Budget Gaming Build
Tunnel Vision
Hey guys, I'm looking to build a budget gaming rig for my brother. I already put together a build that I think will be a good start. I'm just looking for any suggestions you guys have. :) Thanks for the help!
Mostly gaming: SC2, Diablo 3, League of legends, TF2, fallout 3 ect. Some web browsing, email, office word, youtube videos and real easy things like that.
Our budget is at most $1000. If possible, the total for just the parts should be below 1K so there is a little headroom for shipping.
3) Where do you live?
Pennsylvania (USA)
Case, CPU, GPU, PSU, Mobo, RAM, HDD, ODD, Wireless card, Win7, and a monitor.
He will be reusing his mouse, keyboard, and headset.
6) Will you be overclocking?
No
Most likely a 22' monitor
We play on buying the pc before the rebates end. Probably on july 31st.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Not many features are required. Onboard sound is a must because I want to save to money instead of buying a sound card. I would like a mobo with sufficient heatsinks (especially around the cpu area) because I don't want overheating to be an issue in the future.
Nope, I will be buying Win7 64bit OEM
Here is the build I have pieced together on newegg so far:
Case: Lian Li Lancool PC-K58W == $65.99
Mobo: MSI P67A-G43 (B3) == $124.99
CPU: Core i5 2300 == $184.99
GPU: XFX 6850 == $159.99
RAM: Corsair XMS3 4GB CMX4GX3M2A1600C9 == $37.99
PSU: Corsair CX600 == $69.99
HDD: Western Digital Caviar Blue 1TB == $59.99
ODD: Asus DRW-24B1ST/BLK/B/AS == $20.99
Monitor: Acer V223WEJbd 22' == $129.99
Wireless Adapter: ASUS PCE-N13 == $29.99
OS: Windows 7 Home Premium 64 Bit OEM == $94.99
Total: $979.89
(This number does not include taxes or shipping and it does not include the 60 dollars in mail in rebates that are with these items)
I do have one question however. Is the memory I selected compatible with this mobo? For the life of me I could not find the list of compatible modules for this board.
Thanks for the help guys!
For an extra $10, you can get a small clock speed increase and the possibility to OC:
$320 - Intel Core i5 2500K CPU + MSI P67A-G45 Intel P67 ATX Motherboard Combo
PSU wise, I recommend this PSU since it actually provides more power than the Corsair on the +12V rail:
$70 - Antec NEO ECO 620C 620W PSU
HDD wise, get this faster hard drive for the same price:
$60 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
You'll save $6 by going with this DVD burner once you factor in shipping:
$20 - LG iHAS124-04 DVD Burner
You'll save another $10 via free shipping by going with this similar monitor:
$130 - Acer X223WDbd Black 22" LCD Monitor
You'll save another $9 by going with this RAM (which should work with the above mobo):
$28 - G.Skill Ripjaw Series F3-10666CL9S-4GBRL 4GB DDR3 1333 RAM
I would spend the extra cash for a faster GPU:
$190 - XFX HD-687A-ZNFC Radeon HD 6870 1GB PCI-E Video Card
Any other suggestions?
I may use just about every one of your suggestions Danny Bui. :D The only one that I"m not sure on is the video card. I'll have to see how much money is left over after shipping is calculated in.
I know PA is pretty big, but there's a Microcenter in Philly that might let you save a few bucks on your CPU (if it's out of your way it's probably not worth the savings.)
Also, for that GPU, be sure to get this combo instead:
$190 -- XFX Radeon 6870 AND Shogun 2 Total War (comes in the Newegg box as a free Steam key) AND Dirt 3 (after you register the card they give you Dirt 3 for free.)
If he is close enough to get to one the i2500k is 180 there and until the end of the month (tomorrow, I realize it's not much time) they have save 40 on any motherboard and cpu combo and also there is an msi mail in rebate for 20 off. If you can get there tomorrow it should let you save quite a bit.
