johnnyreed
- Apr 29, 2010
1) What will you be doing with this PC? Primarily MMORPG gaming
2) What's your budget? $800 shipping included
3) Where do you live? Oregon
4) What exact parts do you need for that budget? Everything but monitor, peripherals, and OS.
5) If reusing any parts, what parts will you be reusing? Nothing reused.
6) Will you be overclocking? No
7) What size monitor do you have and/or plan to have? 23in
8) When do you plan on building/buying the PC? Within the week.
9) What features do you need in a motherboard? Firewire. Esata
10) Do you already have a legit and reusable/transferable OS key/license? No.
Thanks for any input, I appreciate the help.
