Hey guys
I've decided it's time to put together a system for the first time and I need some help. Right now I'm on a Dell Dimension 8400 from 2004.
Largely gaming, but some light video editing and photoshop work as well. I mostly play fps games, but enjoy other types too. I'm currently playing TF2, Fallout 3, and Left 4 Dead.
$250 - $300. I really don't want to go over $300 but if absolutely necessary I can stretch it.
Tax and shipping included.
3) Where do you live?
Central Pennsylvania.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
I need a new CPU, motherboard, case + PSU and ram (3-4gb). Also possibly a new hard drive. I'm not sure if I should transfer the hard drive from this pc into my new one or if I'm better off buying a new one. I believe the HD in this computer is a Seagate Barracuda 160gb (sata).
Thinking of reusing the optical drives, sound card (audigy zs), video card (8600GTS) and like I mentioned above the hard drive as well.
6) Will you be overclocking?
No plans at the moment, but if possible I'd like to have an option to do so in the future.
7) What size monitor do you have or plan to have?
I have a 17 inch LCD with a max resolution of 1280x1024. In the near future I may upgrade to a 20-21 inch widescreen LCD.
As soon as possible, ie. right away.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Having crossfire/sli would be nice for adding a second video card, but not totally necessary. Don't think I need RAID. Firewire is also not a necessity (but nice to have).
I've done some reading and browsing on Newegg and found a couple of parts that look good, but again as this is going to be my first build I am inexperienced and unfamiliar with a lot of things.
For the CPU, the E5200 Wolfdale looks appealing.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116072
This case also comes with a 585W PSU so it seems pretty good for $80 but I have been warned against buying case + psu combos.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811121065
Anyway what do you experts think? Appreciate all the help I get.
