Budget Gamer
Shadinn
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing?
Mass Effect 3, Battlefield 3, Diablo 3, WoW, Guild Wars 2, Skyrim
$700 USA
Jackson, MS
Processor, Motherboard, Memory, Hard drive, Power Supply, Case, DVD burner
New Crucial M4 SSD 128 I already bought. http://www.newegg.com/Product/Product.aspx?Item=N82E16820148442
New EVGA SuperClocked GTX 560 Ti I already bought. http://www.newegg.com/Product/Product.aspx?Item=N82E16814130610
Mouse, Keyboard, Monitor, Speakers
6) Will you be overclocking?
No
LG 22" 1680x1050 (will probably get a better monitor in the future but let's not worry about it for this build)
Next few days. Have already received the SSD and Video card.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
USB 3.0, SATA 6Gb
Windows 7 x64
Good to hear.
I have an older Creative Labs Audigy 2 ZS sound card. Will this sound card be better to use than the on-board sound on that Intel motherboard? I have the Kiplich 2.1 ProMedia speakers.
Good to hear.
Nearly any soundcard will sound better than onboard.
Also, this memory is a couple bucks cheaper, for pretty much the same performance.
Also, if you can, I'd go for this motherboard, as its more high-quality, has an easier to work with (UEFI) BIOS, and has more features overall. Also looks prettier :p
Other than that, Shadinn's build looks great. You could go for a cheaper case, if you wanted to, the Corsair isn't the best deal around, but they are known for good cable management options, and it's still a solid case.
Probably since earlier today, Newegg now offers free shipping with the Corsair Carbide Series 400R case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139008
Considering that the price difference is $10, I'd spend the extra $10 for the 400R.
As for the PSU, I'd spend the extra $3 for a better quality and larger amperaged PSU:
$73 - Antec NEO ECO 620C 620W PSU
The Antec Neo Eco 620W has 48A on the +12V rail whereas the CX600 has 40A on the +12V rail. Pretty large difference in power capability.
Besides what I said, looks fine to me.
