Budget Desktop Browsing/HD/Gaming Build
Ario
I am looking to build a budget desktop for general use. I've answered the questions below to assist with this, but if anyone is willing to help and needs more info I'll be checking and able to respond regularly.
This desktop will primarily be used for web browsing, movie watching and flash games. I would like it to also have a little bit of gaming potential for games such as Rift and potentially Guild Wars 2 on release.
Preferably I'd like to keep it at ~$400 or a bit below. This doesn't need to include tax and shipping, but alas it would be nice if it did.
3) Where do you live?
Just moved cross country to Lynnwood, WA.
I'm looking at pretty much a fresh start, which would include the following:
Case
Power Supply
CPU
GPU
RAM
Motherboard
DVD or Blu-Ray Drive (Blu-Ray would be preferable, but cost is obviously a factor)
Hard Drive
Wireless Access Point
Monitor (optional as I may purchase a new HDTV or high resolution monitor shortly after this build)
Keyboard (optional)
Mouse (optional)
I have another desktop that I am thinking about upgrading, which would make the following parts available for this build though this is unlikely due to budget constraints:
GPU: BFG Tech BFGEGTX260896OCE GeForce GTX 260 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Power Supply: Antec EarthWatts EA650 650W Continuous Power ATX12V Ver.2.2 / EPS12V version 2.9
6) Will you be overclocking?
Probably not, but if I do it would be minimal.
I would like to potentially hook this up to a HDTV (not worried about response times or high resolution), but I could be convinced to go another route.
I plan on buying within the next two weeks.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Nothing in-particular as long as it is functional and stable.
I plan on using Windows 7 Ultimate 64.
If I were to take the GPU and power supply from my old machine I would need to look into replacing those for that machine (of course). The other relevant parts of that machine are as follows:
Case: Antec Nine Hundred
CPU: AMD Phenom II X4 955 Black Edition Deneb 3.2GHz
Motherboard: GIGABYTE GA-MA770T-UD3P AM3 AMD 770 ATX AMD
Memory: OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
It is unlikely that I will be going the route of taking parts from the old desktop for this one, but if someone is feeling generous and wants to throw recommendations out in that direction I would appreciate it. Any help on the standard build, without part reuse, is also greatly appreciated (as that is most likely my route even if I were to raise my budget to $500-600). I typically prefer ordering through newegg as I haven't had problems with them for my last few builds.
Thank you!
$100 - AMD Athlon II X2 250 CPU + Biostar A880G+ AM3 AMD 880G HDMI Micro ATX AMD Motherboard Combo
$40 - G.Skill Ripjaw Series F3-10666CL9S-4GBRL 4GB DDR3 1333 RAM
$45 - Western Digital WD5000AAKX 500GB 7200RPM SATA 3.0Gb/s Hard Drive
$20 - Asus DVD Burner
$58 - Antec NEO ECO 520C 520W PSU
$60 - Cooler Master HAF 912 RC-912-KKN1 ATX Case
$28 - Asus PCE-N13 Wireless Adapter
Total: $351 plus tax and shipping
No dedicated GPU so rather limited gaming potential but the PSU and case will allow you to add most GPUs you want later on. Though do note that you could probably get the GTX 260 for $50 used off our For Sale/For Trade Subforum
Thank you! I'm terribly at pricing out low end systems so this really helped out.
I might make a couple changes to this to try and fit a dedicated GPU in.
Hossdaddy pointed this combo out to me a couple days ago:
$55 - Seagate Barracuda ST3500413AS 500GB 7200 RPM SATA 6.0Gb/s + Sony Optiarc CD/DVD Burner Black SATA Model AD-7260S-0B
That saves you $10. Another $6 can be saved by going to:
$34 - G.SKILL Value Series 4GB 240-Pin DDR3 SDRAM DDR3 1333
Consider this case for another $25 off:
$35 (use EMCKDJC32 for free shipping) - NZXT GAMMA Classic Series GAMA-001BK
And this WiFi adapter for $8 off:
$20 - TP-LINK TL-WN781ND IEEE 802.11b/g/n PCI Express Wireless Adapter
So now we've trimmed $49 off Danny's build without sacrificing too much (a bit, to be sure) but now we have $98 to spend on a GPU.
So, if you can go $12 overbudget, consider this GPU:
$110 (before $20 MIR) - ASUS CuCore Series EAH5770 CuCore/2DI/1GD5 Radeon HD 5770 1GB
So your new total should be: $412 before $20 in mail in rebates. This won't be a screamer at 1080p, but should run a lot of 3D games at low to medium settings, and some older ones at high. It won't have any problems with Flash based games, web browsing, or movies.
Those changes works for me.
Starting to lose my touch :)
Thanks! Looks pretty good. I think I'm willing to go a little more over budget on the case for a Antec 300 as I have an Antec 900 for my main build and really enjoy it.
So final build would be:
Antec 300 Case
Radeon HD 5770
4GB G.SKILL Ripjaw Series
Seagate Barracuda 500GB + Sony Optiarc CD/DVD Burner Black
This sound good? Probably going to order tonight.
I have an Antec 300, and I would urge you to consider the Cooler Master HAF912 that Danny originally linked to. The 300 has poor cable management for its price. See this post for a picture of how mine turned out. Admittedly, I'm not the most patient guy, but it was tough fitting any cables back behind the drives. From what I've heard, the 912 is a lot better in this regard. It's also currently cheaper.
with a budget this tight cable management should be the last thing he is worried about. I would suggest that he gets the cheapest decent case he can and spend the rest on a stronger cpu. There are plenty of coolermaster's with free shipping for $39.99.
I think he wanted to increase his budget to get away from the NZXT Gamma I suggested for $35.
I just increased the budget because then I will have matching cases. There isn't any technical reason why. Might seem to be a waste for some, but it keeps my townhouse looking good, which is kinda nice. I ran out of time last night to order, which may have turned out to be good...
Just saw that ASUS VH236H Black 23" 2ms Full HD Widescreen LCD Monitor w/ Speakers 300 cd/m2 20000 :1 (ASCR) went on sale for $170 ($150 after rebate) and I think I have to pick that up. My current rig is:
GIGABYTE GA-MA770T-UD3P AM3 AMD 770 ATX AMD Motherboard
Antec Nine Hundred + EA650 Black Steel ATX Mid Tower Computer Case 650W Power Supply
OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model OCZ3RPR16004GK
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor HDZ955FBGIBOX
Is there anything in there that I would need to upgrade to make full use of the monitor for gaming? I could then sub parts out of this for the new budget build. Sorry if this got confusing (again). I'd be able to raise the budget to about $700 - $800 minus the cost of the monitor to assist in upgrading my primary system. Would I be able to put the DDR3 1600 memory from the old system into the new (which only supports up to DDR 1333) and grab 8GB for the old system? Worthwhile? Then I suppose the question is what memory to go with? Advice appreciated!
You should be able to put the 1600MHz DDR3 into your new system. I would try and run it at 1333MHz at 1.5V if possible.
You'll want a new graphics card as well. What CPU do you have? And for your $800 budget, does that include the cost of the new system as well? So $800 for upgrade to your existing + the new system?
I have a AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor HDZ955FBGIBOX in my old system and it isn't overclocked at all, which I would be comfortable overclocking it as I am not too worried about its life expectancy. I'll be building a completely new gaming system early to mid next year.
The $800 includes the new system as well. So yep, $800 total for upgrading the existing system and building the new system. I can go a bit higher if it is warranted. What I could probably do is take the GPU and memory out of the existing system and put it into the new?
Would these upgrades be feasible or are there better out there?
MSI N460GTX Hawk Talon Attack GeForce GTX 460 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
Then I would pull these out of my existing build and put them into the new build:
I am a bit worried on if that memory would work in the new system as I believe it is rated at 1.7V. Still think it would be alright?
These changes and the monitor would bring my total before shipping and tax to: $727.90 before $60 in MIR.
Yeah that might work. I don't know how well a GeForce 260 will do with Rift or Guild Wars 2 but it would more than handle your other needs.
I'm not entirely sure where your budget is at since I don't see any dollar signs in your planned build. But to upgrade that system, on a 1080p monitor, consider at least a 6870, but preferably a GTX560Ti or 6950 for about $220 or $230. 8GB of 1333MHz RAM is about $75, 1600MHz is about $83. So for about $300 you should be set on the upgrade side.
I've been running Rift on my GTX 260 at maximum everything with rather... unhappy fps. So a significant upgrade to the GTX560Ti may be a good idea. With that and the memory the total comes to $772.90.
Would it be worth going for a slightly more expensive GPU EVGA 01G-P3-1561-AR GeForce GTX 560 Ti FPB (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready over the PNY?
Well, originally you specified that the new computer (the $400 one) possible run Rift or GW2. If that's the case you may want to upgrade the GPU in that system as well. But for flash games it'll be fine.
Right. Sorry about that, I figure as long as the new machine can run Rift (some other stuff) at decent graphics it should be fine. Don't need it to be running everything at max. Do you think it would be worth going with the EVGA over the PNY?
One other question:
Weekend deal of G.SKILL Sniper Low Voltage Series 8GB (2 x 4GB) DDR3 1600 (PC3 12800) Desktop Memory for $76.49. Would I be better off going with that over the G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL for $85?
Wow, that is some low voltage stuff -- 1.25 at 1600MHz! I think that should work with your system and if it's cheaper I see no problems going that route. Even the timings are the same.
