Budget Build
DonoHAM
This is a budget build that I will attempting to do in 1-3 months. I will be using the case of this computer and will be getting a hard drive from a friend. I also have a 600W PSU 80+ only used it for 2 months at max. I also have a 550ti GTX Zotac AMP!.
My budget is roughly 300-400$ but try to keep it low end. 8GB of RAM is wanted.
This is the case I will be re-using http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c01527396
Gaming[BF3], Web browsing and thats it
$300-400 with tax and shipping
Kansas
CPU/RAM/MoBo
Case that's all
6) Will you be overclocking?
If possible
1440x900 not sure on size
1-3 months
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Not sure
64 bit
1-3 months
Too soon to start planning a build. Our parts recommendations tends to change monthly and sometimes even weekly. As such if you want an up-to-date build list, please come back when you're 2-3 weeks away from buying. It does you no good to plan this far in advance.
Which 600W PSU?
Double check to make sure that the case uses standard front panel connectors.
Basically just look to see if the cables from the power button are the standard "PW" and "RW" connectors.
