Budget Build w/ Future Upgrades in mind
glazer1972
Mostly Web Browsing, Some Kids Games, Maybe some photo shopping. Nothing too taxing.
I'd like to keep it around 200-300 shipped.
Lufkin, TX
Mobo, CPU, Cooler, Ram, DVD Burner. GPU? I'm thinking something on a 1155 with an Intel.
Antec Solo (original) Case, Seagate ST31000333AS 1 TB 3.0 G/S, 120mm Nexus Exhaust Fan, 2x Nexus 92mm Intake Fans, Zalman Fan Controller? Corsair HX520W PSU, Dell 2407WFP Monitor, and Klipsch 5.1 ProMedia.
6) Will you be overclocking?
I would like the option to or at least a board capable of it for future possibility.
1- 24" Dell 2407WFP 1920x1200.
In the next month or so. No hurry. Just wanting something Faster than my old 2.0ghz Socket A.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
Would like good on board audio if possible. Could probably use on board video if it would run the monitor for browsing etc. I wouldn't mind having a board capable of having a couple of usb ports for the front. Not sure otherwise?
I have Windows XP Pro 32 bit and 64 bit and Windows 7 Pro 64 bit.
$235 - Intel Core i3-2120 + Gigabyte GA-Z68A-D3H-B3 Intel Z68 ATX Motherboard Combo
$37 - G.Skill Value Series F3-10600CL9D-8GBNT 2 x 4GB DDR3 1333 RAM
$16 - LG GH22NS90B DVD Burner
Total: $288 shipped.
What do you think of the GIGABYTE GA-Z68AP-D3(R2.0) as opposed to the one in the combo. It is 109.99 w/ an additional code for 10% off.
Adding the 2120 separate has a combo savings w/ dvd burner of $127.99.
Add the memory for $47.99 - $20 MIR.
Total of $254.98 after the savings and MIR. $274.98 w/o MIR.
The combo deal knocks the Gigabyte mobo I recommended to ~$106 shipped. The 10% promo only knocks down the Gigabyte mobo you linked to $100. But once you factor in shipping, the motherboard you chose comes out to ~$108 shipped. The motherboard you chose is a new motherboard with barely any reviews. The mobo I chose has several solid reviews and has been out longer. So I still recommend my original choice.
What RAM are you talking about?
This.. I got mixed up but this was recommended by someone else.
The seperate CPU does include the DVD Burner and I mentioned the other board because it was not a micro. Never had a micro before but of course I've only had two and they were both socket A. :eek:
Do you think it would be super beneficial to splurge now and get the i5-2500k?
The stuff you recommended in the post above. The only reason I mentioned the other board was that it was not a micro. Never had a micro before but of course I've only had two and they were both socket A. :eek:
The RAM I recommended is only $37 and has no MIR. You wrote "Add the memory for $47.99 - $20 MIR." Was that a typo?
I edited the post after you quoted me. No Typo. The stuff I linked to is $47.99- $20 MIR = $27.99. http://www.newegg.com/Product/Product.aspx?Item=N82E16820145315&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10440897&PID=3891137&SID=rewrite
Not a good choice as it's not fully rated at 1.5V. With Intel CPUs, RAM rated higher than 1.5V have a higher chance of damaging the CPU. The RAM I recommended is rated for 1.5V only. The RAM you chose has a variable voltage rating which means that some sets might require 1.65V. In addition, since the MIR isn't in your hands yet, that Corsair RAM is still $48 to me. As such, not a good deal IMO.
For the usage you've described, the Core i3 should be more than enough.
