1) What will you be doing with this PC? Gaming? Photoshop? Web browsing?
-I will be using it as a general PC with a slight trend towards Games. I have a PS3 for almost all of my gaming and a Laptop for most computing, but I'd like a PC to run things like the new SimCity well, Starcraft 3, Diablo 3, etc... I won't be playing (or don't intend to at least) FPS or the type, but you know how it is with new toys...
-I'd definitely like to keep it below $1000. $500 is even better, but I will make concessions for stuff like Graphics cards. I tend to spend a little more for the next better option...
-Canada, Toronto.
4) What exact parts do you need for that budget?
-Mobo, CPU, RAM, GPU (HD too, but I'll spec that out myself...so for budgeting puposes, we'll assume I'll reuse one)
-I'll use the case from my current PC, could probably use the PSU as well, but will take suggestions since I cant remember make/model...I think its 700W
6) Will you be overclocking?
-I doubt it
-24", 1920x1080
-Any time before Februrary
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0, SATA 6Gb/s, eSATA
Yes, 64-bit Windows 7 Professional.
Forgive the vagueness, I wish I could say what parts I had in mind, but I can really go any direction with this. I used to prefer Intel exclusively, but that is no longer the case.
-Canada, Toronto.
-I doubt it
-24", 1920x1080
