I'm helping a retired friend with a super-budget build to replace a system fried by lightening. I can piece a high end rig together with no problem, but the low end absolutely perplexes me. Here we go:
Browsing, email, Office
$400, all-inclusive
Knoxville, TN
Case, PSU, CPU, RAM
HDD (250GB SATA), DVD Drive (SATA)
6) Will you be overclocking?
No.
1280x1024, not sure of size
Immediately
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Onboard video as main GPU; onboard audio and LAN are needed
Yes, Windows Vista x64
$400, all-inclusive
Knoxville, TN
Case, PSU, CPU, RAM
No.
Immediately
