deffibaugh
- Aug 23, 2011
I plan running both Windows and a Linux distribution that I will be Android development in. When I am not working I would like to be able to play games once in a while. I definitely want to run Deus Ex: HR, Starcraft II, Diablo III, and Skyrim if possible. I also play indie Steam games and emulators but that shouldn't be a problem. I don't need crazy performance I just need playability.
about $500
3) Where do you live?
Pennsylvania
CPU, RAM, Graphics Card, Motherboard, Storage, Case, PSU
Nothing to reuse
6) Will you be overclocking?
Not likely since its a development machine as well.
22inch 1080p monitor
very soon
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
I just need a basic motherboard. Something like an H61 SandyBridge board will be fine. I won't be doing much on the machine but development and occasional gaming.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
I have a Windows 7 licensee for both 32 and 64 bit.
Basically, I am interested in building something similar to this: http://www.anandtech.com/show/4456/sandy-bridge-buyers-guide/3
I am just trying to figure out what graphics I need to run Deus Ex at 1080p adequately.
about $500
Pennsylvania
Nothing to reuse
very soon
