Hi folks,
I recently had my P4 Dual Core go up in smoke and I am at the moment forced to rely on my backup P3 Server to use as a workstation so a new build is in order. Unfortunately as luck would have it, I have to replace the engine in my car and that took a large chunk of my budget away. So in the meantime I am pondering a bearable temporary rig until I can cut loose some spare funds for an upgrade. The real fun part is I need to come in under $500 and while I have done that, I am not entirely sure my choices are going to be appropriate since I haven't been tracking hardware for awhile. So before I pull the trigger and spend my money, and before I spend too much time wanting to curse my auto mechanic over what should have been I am asking here for a review.
Usage, mostly as a workstation with several Virtual box VMs running programming tools, web servers and SQL servers of differing times. I do mild ancient games for the most part. Civ 4, RTCW: Enemy Territory.
I would like to do Battlefield 2, Enemy Territory: Quake Wars and Ghost Recon 2: Advanced Warfighter at a reasonable fps on this machine. I don't expect 1900x1600 16AAF on this box but I would like a reasonable 1024x768 or perhaps my default res of 1280x1024 for games (Actually since I have a dual monitor setup I run 2560x1024 most of the time.
A few considerations to explain my choices. First I want at least 4gb of ram that I can expand later to 8 or 16gb, mostly because of the VM's I run since there are times I really may need to run 3 of them plus my host system for testing on my usual workload. I want a dual core processor since I have had them since running dual P3-866's in 2000. I have some rendering apps that do use it when I do the family video and it would be nice to keep. My usual preference has been Intel, but in this price I know AMD rules usually. As for Video I have had and enjoyed both NVidia and ATI over the years and usually upgrade every other year if I can to whichever is holding the sweet spot, one crevat this will be my first PCIe video card (yes I ran a P4 with AGP, I was stubborn).
Answers for the Offical FAQ Questions:
1) What will you be doing with this PC? Mostly as a workstation, mild Photoshop, modest gaming.
2) What's your budget? Are tax and shipping included? $500- with shipping and taxes. I can likely pick up my parts at either Fry's, mWave or the Egg depending on the deals
3) Where do you live? SoCal
4) What exact parts do you need for that budget? CPU,MB,Ram,Video,Case,SATA Drives (HDD & DVD Burner)
5) If reusing any parts, what parts will you be reusing? Keyboard, Mouse
6) Will you be overclocking? No
7) What size monitor do you have and/or plan to have? Dual 21" CRT
8) When do you plan on building/buying the PC? Next two weeks
9) What features do you need in a motherboard? RAID 0/1/10, Firewire, Built in LAN
10) Do you already have a legit and reusable/transferable OS key/license? Yes
Here's what I picked out:
ASUS M3A78-EM - $78.99
The layout for an mATX seems alright and it will support 8gigs of ram if I choose to slap that much into it. Not a lot of expansion slots but then I doubt I need many, I tend to use a USB Headset most of the time so I don't really need better audio card but there should be room for one if I choose to not use either the on board or my headset options.
AMD Athlon X2 4850e - $59.99
I have read that this is a nice low wattage dual core processor and while I know there are some faster ones for just a few bucks more, is that extra clock speed worth the higher power draw given how limited I know this machine will be?
Kingston HyperX 4GB (2 x 2GB) DDR2 800 - $49.99
Nothing particularly special about this, but I have always personally had good luck with Kingston warranty wise over the years and unless there is a good reason to switch I tend to buy their ram.
HIS Hightech Radeon HD 4670 IceQ Turbo 512MB - $79.99
Yes it's a Crossfire enabled card, which I doubt I will ever use but it seems in a reasonable price point, yet of all the parts this is the stickler for how it would preform that I would love an opinion on. Part of me wonders if I would be better off going with an ATI 38xx card yet with the on board ATI 3200 I do want something better. Ideally I would love to find out the sweet spot in the $75-100 Video card list now.
HITACHI Deskstar 7K1000 750GB 7200 RPM SATA 3.0Gb/s HDD - $69.99
I have a mix of Maxtor, Seagate and Hitachi IDE drives now I use in other boxes. Unless someone tells me this makes tank like noise levels, it seems to be an average model these days for it's size.
LG 22X DVD±R DVD Burner SATA - $24.99
I do have an IDE burner but I would prefer to keep it in the box it's in and I've had LG, HP and Sony drives before. This just looked reasonable.
Rosewill R804BK ATX Mid Tower Case 350W PSU - $46.99
Yes I noticed only 1 SATA connector but I have a few spare molex to SATA power ones I can use. I do have a large tower case I picked up awhile back but if there are real objections for this case/psu I could use a psu recommendation in this price point.
I am reusing my existing 21" Sony Flat screen CRT's and I have my MSDN copy of XP64 bit for this box ready to go. So minus shipping taxes etc that leads me to around $411 or so which is under what my target was.
Am I better of going for the AMD Athlon 64 X2 6000 3.1GHz at $89 instead of the 4850e? Should I do a different graphics card? Would throwing in another 4 gigs of ram make a difference given the budget nature here?
I do appreciate all comments and while I have nothing against an Intel build I really couldn't fit a decent c2d system for under $650.
Thanks
Thanks
