Budget Build $400 review
Blu-Flames
Ok so i have came up with this build for $400 dollars. Thats the most i can spend as of right now. I am going to be using it for surfing iternet/ burning, downloading. and BF2 and some newer games.
LITE-ON 20X DVD±R DVD Burner With 12X DVD-RAM Write Black SATA Model
$31.99
RAIDMAX Scorpio ATX-868WBP Black 0.8mm Japanese SECC ATX Mid Tower Computer Case 420watts PS2 ATX12V Power Supply
$56.99
ABIT AN52 AM2 NVIDIA nForce 520 MCP ATX AMD Motherboard
$68.99
Western Digital Caviar SE WD2500AAJS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive
$64.99
ASUS EN8500GT TOP/HTP/256M GeForce 8500GT 256MB 128-bit GDDR3 PCI Express x16 HDCP Ready Video Card
$68.99
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
$46.99
AMD Athlon 64 X2 4000+ Brisbane 2.1GHz Socket AM2 65W Dual-Core Processor
$57.99
total-$407.93
Looks fine but replace the 8500 with a x1950pro or a 7900gs
I would not recommend using that case and PSU combo. Generally, most PSUs that come with the case suck, with the exception of Antec combos. You may have $400 but it's still pretty stupid to cheap out on the PSU since it is the most important part of the PC. It delivers the power to your PC so if the PSU gives too much, too little or alternates between the two, it can damage/kill your system.
So I recommend this case/PSU combo instead since it comes with a quality PSU, the Seasonic made Earthwatts 380W PSU:
Antec NSK4480 ATX Case With Antec Earthwatts 380W PSU - $68
To cover the extra costs, you can do any of the following:
- Swap the G.Skill RAM out for this:
Super Talent T8UB2GC5 2GB DDR2 800 RAM - $36
- Drop the hard drive down to a 160GB drive:
Western Digital WD1600AAJS 160GB 7200 RPM SATA 3.0Gb/s Hard Drive - $50
- Swap out the mobo for this:
ASUS M2A-VM AMD 690G mATX Motherboard - $62
And RAM for this:
A-Data ADQVE1A16K 2 x 1GB DDR2 800 RAM - $42
Any of thos options would be good ways to fit in a decent PSU and case.
Both card will ne over my budget can you help me find a video card that is better than the 8500
Try and find a second hand one or somthing, the 8500 is complete crap.
The 7600 is way faster then the 8500 from personla experience.
There are some good cases to be found for under $50. CM and Rosewill come to mind. Here's a decent enough case as an example.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119106
At the very least you'll need a 1950Pro to do some decent gaming and even then the 1950Pro is becoming obsolete. You could use a 8600GT but its not that great IMO. Get the best card you can afford now and then Q1 2008 step up when the new high end cards from nVidia come out. There should be big price changes by then. Better cards that are expensive now should drop a fair amount. Also it gives you time to save up.
Edit: When it comes to nVidia 8xxx series cards they are not really good for gaming unless you are getting a 8800 type. Just my opinion anyway.
x1950 pro is not obselete for todays games. it is fine except from crysis.
yes but the 1650 pro is too slow for most games, depending on the resolution.
OP what res do you game at?
When your are trying to build a system for really cheap you might just have to accept not playing at native resolution.
If you try a bit harder you can find things cheaper. cheaper=more money for better card. better card = native res. :cool:
X16XX's, 7600's, 8500's all suck badly in current games and won't even handle 1024x768 unless you turn off a lot of settings. The 8600GT/2600XT are the minimum for decent gaming, and I still can't recommend them given the price/performance of the $160 3850 . If you can't afford such card then stick with onboard video till you afford it. Ruining your gameplay experience for a few bucks has never been a good idea.
++1
Didnt say it was obsolete. I said it was 'becoming'. Which is natural as new and better games come out that require better cards. Many people consider it the low end right now for decent gaming. I'm one of them but thats just my own opinion.
Did you ever have the x1950pro? its not a slow card for todays games, and im saying this compared to a 8800gt. i bet 50% of people on these forums probably still game on a dx9 gpu.
ok im going to be playing at 1280x1024
how about this card
Radeon X1650GT 256MB 128-bit GDDR3
And RAM for this:
I agree with the above quoted posts.
i dont really play alot of games... i just need a all around fast computer that can basically do everything.
Alright i did some research and found these 3 video cards. Which one would be he best for BF2 and BF2112 and Counter strike, i really dont care about playing it on max at least it plays good at 1280x1024
GeForce 7600GT 256MB 128-bit GDDR3
Of those cards, the x1650GT should be the best performer..from what i've read it seems to be between the x1650pro and the x1650xt, but with 24 pipelines like the xt and lower clocks.
Both 7600GT or x1650GT are good choices since they perform on par with one another I believe.
Also, please heed my advice about the case and PSU combo made earlier.
ya i changed that case with power supply to this...
COOLER MASTER Centurion 534
Thermaltake TR2 W0070RUC ATX 430W Power Supply
Also so the x1650xt would be the best?
Of those three cards, it should be. If you're looking at that though, I'd really recommend trying to swing a few extra bucks and get something like http://www.newegg.com/Product/Product.aspx?Item=N82E16814102034&Tpk=x1950gt
As far as the PSU..that 430w is decent, but nothing more (i have one on the desk here actually) Try to get an xclio Goodpower 500w. It's only a little more expensive, and is a much better psu. http://www.newegg.com/Product/Product.aspx?Item=N82E16817189005&Tpk=goodpower On that same note, however, it's gonna be very hard in terms of value to beat that Antec Solution series posted by Danny Bui
Regarding the video card, you can buy the following and overclock using 'ATI Tool' or 'ATI Tray Tools'
$50(+$6) - Open Box: MSI RX1650GT-TD256E Radeon X1650GT 256MB 128-bit GDDR3 PCI Express x16 Video Card
Im running at x1950pro now in my q6600 system. Plays very well in all games i play (1024x768), at medium/high settings. Crysis is the only thing that really kicks its ass.. I will probably be upgrading to an 8800gt/waiting for 9800gtx in a few days.
The TR2 is fine for non gaming systems. Any system with a midrange vidcard needs not only more juice on the +12V rail, but better quality power. The XClio Goodpower 500W for $50 is good unless you live in 90°F heat. If you need a case, go with the Antec NSK Danny posted earlier. It comes with a 380W Earthwatts thats not only more powerful on the +12V rail (where you need the power), but its also a much better quality power supply. The EA380W was on sale for <$20AR before, but I think all those deals are over now.
PSU FAQ: http://www.jonnyguru.net/forums/showthread.php?t=1036
PSU Suggestions:
http://forums.extremeoverclocking.com/showpost.php?p=1590883&postcount=193
http://www.jonnyguru.com/forums/showthread.php?t=1460
http://www.jonnyguru.com/forums/showthread.php?t=103
