DaConfusion
- Dec 14, 2005
Hello:
I am helping a fellow coworker build a system to be used to very light home use, and design:
Primary use for this system will be CAD (Pro/Engineer and SolidWorks), FEA/CFD (Ansys, maybe MSC), multi-body dynamics (ADAMS, suspension kinematics software) and vehicle simulation (TruckSim/Adams)
CAD will be used to design/model entire vehicle assemblies (electrical and mechanical components)
The components will be expected to be sent to ANSYS for FEA simulations/improvements.
Possibly dual monitor use.
My co-worker prefers to stay between $800-900, but I would like to estimate the significant increase in performance by going with a $1000 build (shipped with tax). (If there is any significant difference)
3) Where do you live?
Texas
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Will need everything including the desktop case (cpu, ram, harddrive, video card, cd burner)
Already have keyboard, mouse, and monitor. I am not aware of his monitor's dimensions, but I expect it to be <19". I will recommend that he upgrade the monitor since they are quite inexpensive.
Note: this system may be used with dual monitor in the near future.
No internal desktop hardware components will be re-used.
6) Will you be overclocking?
No, but I am open to the suggestion as long as it does not require above average cooling.
Un-sure at the moment, expect monitor to be <19" for now, possibly will use dual monitors in the future
< 2 weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
No special features needed.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
64 bit Windows 7 purchased under student program.
I have looked at the other 1000$ builds currently being discussed and am unsure if I would like to use them since they quote AMD processors. I am under the impression that the i7 processor still performs better, but I havent had much time to research it.
$294.99 - Intel Core i7-930
$109.99 - G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
I am sorry about not posting suggested build components because I am very unsure. I do not think I want to go the SSD route, and am probably leaning towards an ATI card.
The main goal is max performance for the said budget. And the performance needs to be for CAD and computational software, not games. I suspect this means max memory, both for computer RAM and video RAM.
The computer will NOT be used for any games.
Thank you for any help or advice.
Texas
< 2 weeks
