Budget 600 $ build, need suggestions.
Hello, i'm building a computer. I'm going to be web surfing, using ms word, playing games, watching movies, and alot of other things. I know i won't be able to get a good video card because i only have 600 $ for everything (I already have a monitor and a keyboard, and a mouse, and a headset). For video card i'm thinking of a 6800 GS or 7600 GS. I'll probaly be playing RTS games and fps'. I would like to have above 20 fps. I play most games on my GeForce 5600 XT 128 mb @ 20-25 fps so i'm okay. Any suggestions? Oh yeah, i'll be playing games @ 1024 x 768/1152 x 864. Also, after i get this pc, i'm probaly going to buy more Harddrives (i fill up hd's fast) so if that means anything then there ya go lol. thx!
7600GS is a better value of the two cards you mentioned
Anyway, assuming that I'm reading things right, you need a case, power supply. mobo, RAM, CPU, hard drive and cd/dvd drive. I'm also assuming that $600 includes S&H and tax.
So here's goes:
FSP Group AX450-PN 450W Power Supply
ASUS M2N-E NVIDIA nForce 570 Motherboard
AMD Athlon 64 3500+
Kingston ValueRAM 1GB (2 x 512MB) DDR2 533 RAM
eVGA 256-P2-N541-TX Geforce 7600GS Video Card
HITACHI Deskstar T7K250
NEC ND3550A DVD Burner
Total: $523.93
You now have enough for a case of your choosing, for S&H, and tax.
If you multitask alot, I'd suggest scraping together another $100 on top of the $600 for a dual core system (3800+ w/ddr2-800 1gb).
A core2duo build is still possible with that budget:
$180 - Intel Core2Duo E6300
$102 - Kingston ValueRAM 1GB (2x512MB) DDR2-533 KVR533D2K2/1GR
$90 - 3D Fuzion 3DFR76256GSE Geforce 7600GS ($90 - $20MIR)
$56 - ASRock 775Dual-VSTA Socket T (LGA 775) VIA PT880 PRO
$43 - HITACHI 7K160 HDS721680PLA380 80GB SATA 3.0Gb/s
$42 - FSP Group AX400-PN 400W PSU
$513 + tax and shipping
Again, I'll leave the case up to you... you could probably find a cheap $25 one or use your old one, if its not too old. Not the greatest of parts, but still, a damn cheap conroe system. If you need the system now, go for the am2 build.
Hold on, this would save ya another $25 bucks:
http://www.circuitcity.com/ccd/productDetail.do?oid=131002&sourceid=qIrKRRoA1mb8ATGUDHsJ&affiliateid=20026380&carriage=befree&cm_keycode=85&JSESSIONID=FhQWG2mFh5TRqXZgmBcgPG27jZvvVT!270435135!1159332054950
