Budget 2.0/2.1 speakers
sbl03
I'm looking for some 2.0/2.1 speakers. Currently rocking some Sennheiser HD 555s, but really, I need speakers. I like the look of the Soundsticks III and Creative Gigaworks T40s. If not these 2, I'm looking for something <$150, though I've heard the Audioengine A2s are pretty good for slightly more. I listen to mainstream pop/rock and alternative, mostly.
Any thoughts? Thanks.
I just bought some Swan M10's. I will let you know how they are when I get them in on Wed/Thurs hopefully. Granted I am no audiophile, but I feel I have a good judgement on what is good quality.
This is a 2.1 setup with a small 5' sub. I have only heard good things so far so Im excited to hear them.
Swan M10 (the .1 is more like a mid-woofer than a sub, meant to sit on desk)
M-Audio AV40
Samson MediaOne 3a or 4a
All solid 2.0 options under $150, better than anything Logitech/Creative imo (unless you're just after bloated overpowering bass...). I've had the Samson StudioDock 3i for a few years (same as the MediaOne but w/an iPod dock, it's been discontinued) and I'm very happy w/them, paid $120 for them locally and I've had no issues w/them over time (unlike some of what I'm hearing about the AV40's).
The Audioengine A2's are pretty nice for their size, but kind of overpriced at $200 compared to some of those other larger/fuller sounding powered 2.0 sets.
If you go w/a discrete amp and passive speakers you end up w/a ton more options without having to stretch the budget much if at all... It might not necessarily be better sounding but it'll be a more versatile setup as far as upgrades etc. You do need the desk space for at 'least a small external amp and whatnot tho.
I can vouch for the Swans m10, but the middle woofer has to be on the desk between the two speakers. If you can't accomodate that, then I can't recommend it.
I just got the Swan M10's to replace Swan D1080's (moving the 1080s elsewhere)
The M10's seem to have a better range of sound than the 1080's did (I'd attribute that to having tweeter, mid, and woofer, vs. just tweeter and woofer), definitely a bit less punch but I don't find it nearly as noticeable/negative as I thought I would.
The M10's definitely look quite a bit nicer on the desk, certainly a secondary priority but always a nice plus :)
Definitely keep the "sub" on the desk though...
If you want a 2.0 setup, the 1080's are quite nice too, very good range & sound, 5.25" woofers give it a very deep noise, excellent for games & movies (if you can't get a proper subwoofer into the equation)
Later on if I want to hook a bigger sub up to my Swan M10's is that possible or no?
Just curious.
Not really. The sub on the M10 has the amp that powers the speakers. You could buy a sub and just run it in concert with the M10 though. Just plug the sub into your subwoofer out on your sound card.
You are better off getting the partsexpress combo imo. They sound awesome for the price. Just a bit bigger. Get that and a sub from them and you will be BLASTING OFF I can assure you of that.
Alright thanks for the reply. I really wish the m50 had a different style instead of wood.
