Budget 1080P Build
Well, what's your max budget and what's your preferred? I've seen budget builds go from $400 to $1500. You can get SLI for under $900 pretty easily.
$220 - Intel Core i5-2500K CPU
$145 - MSI P67A-GD55 Intel P67 ATX Motherboard
$163 - Corsair 850TX V2 850W PSU + Corsair Vengence CML8GX3M2A1600C9B 2 x 4GB DDRR3 1600 RAM Combo
$60 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
$20 - Sony AD-7260S-0B SATA DVD Burner
$28 - Cooler Master Hyper 212 Plus HSF for LGA 1366 and LGA 1156
$100 - Windows 7 Home Premium SP1 64bit OEM
Total: $736 plus tax and shipping
The above mobo and PSU will support GTX 570 SLI just fine.
Choose your own case. I recommend any of the following cases for GTX 570 SLI:
$90 - Cooler Master CM690 II Advance ATX Case
$90 - Lian Li Lancool PC-K7B ATX Case
$100 - Lian Li PC-7B Plus II ATX Case
$100 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$110 - NZXT Whisper WHI - 001BK ATX Full Tower Case
$100 - Lian Li PC-7FN ATX Case
$110 - Lian Li PC-60FN ATX Case
$113 - Velocity Micro GX2-W Silver Classic Aluminum Case with Side Window
$110 - Fractal Design Arc Mini Tower
$120 - Corsair Carbide Series 400R ATX Case
$130 - Fractal Design Define R3 Black ATX Case
$140 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$140 - NZXT Phantom PHAN-001BK Black Full Tower ATX Case
$140 - Lian Li PC-9F ATX Case
$140 - Cooler Master HAF 932 RC-932-KKN1-GP ATX Case
$140 - Antec Performance One Series P183 V3 ATX Case
$143 - NZXT Phantom PHAN-002OR Black Finish w/Orange Trim Full Tower ATX Case
$150 - Corsair Graphite Series 600T ATX Case
$160 - Silverstone RV02B-W ATX case
$178 - Silverstone RV02B-EW ATX case
$190 - Corsair Obsidian Series 650D ATX Case
EDIT: Totally didn't see the above posts above me. Hmm....
Question:
How much cheaper do you think it could get if I don't go for SLI needs?
Probably around $60.
$28 - Cooler Master Hyper 212 Plus HSF for LGA 1366 and LGA 1156 recommended either way?
If you live in a hot place or don't much cooling in the area, then get the HSF. Otherwise, no need for the 3rd party HS
IF you are prepared to cut out both SLI and overclocking you can save quite a chunk of money by using a non-k model CPU and a H67 board.
