- Dec 18, 2005
Hello, im running x5690 and having this bsod occur randomly. I've ran multiple different oc stress test and they all pass fine. memtest was ran for 9 hours.
i read error code ending in d1 has to do with dram/qpi voltage and ive been upping that. was at 1.33 and it bsod so now im at 1.35
I am trying to run my memory at the rate speed of 1600. My temps are all good.
Does anyone know what i need to do. My cpu is at 4 ghz at 1.3 vcore with bclk of 160. So not really pushing that much
CPU Ratio: 25
BLCK: 160
PCIE: 100
DRAm Freq: 1604
UCLK: 3207 (double)
QPI: 5774 (set to lowest)
CPu Volt: 1.3
Cpu PLL: 180
QPI: 1.33 (1.35 now since it just crashed with 1.33)
RAM Voltage: 1.66
Everything else on auto.
Ram timings ran as suggested by CPUZ for 1600
Dump File : 062920-34015-01.dmp
Crash Time : 6/29/2020 10:46:04 PM
Bug Check String : DRIVER_IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x000000d1
Parameter 1 : fffff805`29fc43a4
Parameter 2 : 00000000`000000ff
Parameter 3 : 00000000`00000000
Parameter 4 : fffff805`29fc43a4
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+1c23a0
File Description : NT Kernel & System
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 10.0.18362.900 (WinBuild.160101.0800)
Processor : x64
Crash Address : ntoskrnl.exe+1c23a0
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\062920-34015-01.dmp
Processors Count : 12
Major Version : 15
Minor Version : 18362
Dump File Size : 780,878
Dump File Time : 6/29/2020 10:47:37 PM
CPU Ratio: 25
BLCK: 160
PCIE: 100
DRAm Freq: 1604
UCLK: 3207 (double)
CPu Volt: 1.3
Cpu PLL: 180
RAM Voltage: 1.66
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Major Version : 15
