BSOD Diagnosis
Looks like your video card drivers have some kind of problem
Code:
3: kd> !analyze -v
*                        Bugcheck Analysis                                    *
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: fffffa800aee94e0, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff8800539aadc, The pointer into responsible device driver module (e.g. owner tag).
Arg3: ffffffffc000009a, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000004, Optional internal context dependent data.
Debugging Details:
FAULTING_IP:
nvlddmkm+929adc
fffff880`0539aadc 4055            push    rbp
DEFAULT_BUCKET_ID:  GRAPHICS_DRIVER_TDR_FAULT
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x116
PROCESS_NAME:  System
CURRENT_IRQL:  0
STACK_TEXT:
fffff880`062d9a48 fffff880`04358000 : 00000000`00000116 fffffa80`0aee94e0 fffff880`0539aadc ffffffff`c000009a : nt!KeBugCheckEx
fffff880`062d9a50 fffff880`0432b867 : fffff880`0539aadc fffffa80`08390000 00000000`00000000 ffffffff`c000009a : dxgkrnl!TdrBugcheckOnTimeout+0xec
fffff880`062d9a90 fffff880`04357e0f : fffffa80`ffffd84d 00000000`00000000 fffffa80`0aee94e0 00000000`00000000 : dxgkrnl!DXGADAPTER::Reset+0x2a3
fffff880`062d9b40 fffff880`04237ec1 : fffffa80`0983a250 00000000`00000080 00000000`00000000 fffffa80`07cc9410 : dxgkrnl!TdrResetFromTimeout+0x23
fffff880`062d9bc0 fffff800`0316ce5a : 00000000`0185d81c fffffa80`07f1f350 fffffa80`066d75a0 fffffa80`07f1f350 : dxgmms1!VidSchiWorkerThread+0x101
fffff880`062d9c00 fffff800`02ec6d26 : fffff800`03048e80 fffffa80`07f1f350 fffff800`03056cc0 fffff880`00ea77cb : nt!PspSystemThreadStartup+0x5a
fffff880`062d9c40 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  .bugcheck ; kb
FOLLOWUP_IP:
nvlddmkm+929adc
SYMBOL_NAME:  nvlddmkm+929adc
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nvlddmkm
IMAGE_NAME:  nvlddmkm.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  50de9218
FAILURE_BUCKET_ID:  X64_0x116_IMAGE_nvlddmkm.sys
Followup: MachineOwner
What are the specs of your PC?
CPU: 3570K
RAM: 8gb DDR3 1600mhz (Corsair Vengeance)
GPU: Gigabyte Windforce OC GTX 670
PSU: Seasonic X750
Mobo: Asus P8Z77-Pro
HDD: Sandisk Extreme 120gb/240gb
I've updated the video driver, hopefully that'll fix it. Although both times it's happened I was on the latest drivers.
GeForce 307.74 WHQL just came out, so I just updated again. (previously used GeForce 310.90 WHQL)
CPU: 3570K
PSU: Seasonic X750
I've updated the drivers several times now and it's still occasionally getting BSOD's. Any thoughts on how I should go about fixing it?
Latest DMP file:
https://docs.google.com/file/d/0Bx0w1LjN2tP4Wmhla2c3S2NKT1k/edit?usp=sharing
