BSEL mod tin foil ?
Most of me is saying that tin foil is probably a bad idea.
Its your cpu do what you want, but......
Conductive ink pens are not hard to find or expensive. Rear Window Defroster repair kits with conductive ink found at auto parts stores in a pinch. Taping on a bit of tin foil ? I will pass.
So i went out and did the mod with tin foil... and it didnt work (fans spin up, no post)
Im very sure I did it correctly, I guess it just doesnt work.
Luckily, my CPU still does :)
If anyone could help me find a circuitwriter that will ship to the Netherlands, that would be great!
copper conductive tape from Ebay should ship anywhere. That's what I've used and works great. Neater than ink/pens and can be pre-cut with precision.
