I was messing around under my desk, forgot I had something plugged into my front side USB port, and my back hit the plug. It snapped the inside of the USB and it's now unusable. My computer still boots, but it stalls for a while at the boot screen (I think that's called POST), and I am unable to get into the BIOS. At least it still boots to Windows so I can use it, eventually.
My case is the Apevia X-Cruiser. Is there any way I can fix this, any part I can buy to fix the USB side connection? I'm not really into case modding, but I think a friend of mine might be willing to try it.
My alternative would probably be to gut my computer and set it up into a new case. I don't want to do that. However, if I did, a question comes to mind: Can I use the USB 2.0 connection and connect it to a USB 3.0 port on a case? Would I at least be able to achieve USB 2.0 speeds this way? If I decide to ultimately change the case, I might as well get the case I want for my next build.
