My daughter's computer seems to be broken, and it is a bit weird. It will power up, though I'm not convinced the hard drive is spinning up (WD). That wouldn't normally be a troubleshooting issue, as the MB should at least post.
At this point, it receives power to the MB, fans spinning etc... but there are no post codes at all. Would that indicate a bad motherboard? It is an older AMD processor on an ASUS MB if I remember correctly. I'm thinking the lack of a post beep or error code beep indicates the MB is shot... any advice or troubleshooting procedure I should try? Thanks
