Bought Vertex 60GB, Returning for Agility....
Headbust
Yes i know benchmarking the vertex is better...actually i was just going to say screw it and just return it and thats it but decided to get the cheaper agility as i have been reading in real world results they basically is no difference between the two.
My main reason for returning the vertex was the price i paid...$245, yes i know i could have waited for a much better deal but wanted it now figuring what the hell and did it anyway. Once i got it i was impressed, but also not impressed at the same time, everything was much snappier of course, but it just was not worth $250 so i returned it. After i reinstalled my 6400aaks i was more unimpressed, it basically felt the same. The only time the SSD seemed to make a difference was that first time you would open a program up, which i guess is the whole point of it but again the price/performance gain for $250 was not worth it.
Just bought the agility for $180 shipped with a $30 rebate and 6.5% bing cashback, so the end price will be about $140. I can live with that for the performance it will give me if it matches the vertex. Also just to add i probably did not give the vertex a long enough trial, i mean honestly it was in my system for about 3hrs at most and i probably only gave it a good hour and a half of usage after getting everything set up the way i wanted. I think the longer i would have used it the more impressed i would have been(especially going back to a mechanical)
Just wanted to share my story!
Interesting that you didn't notice an immediate difference in the performance after you put the 640GB back in. I've seen several people here say that going back to a mechanical HD as a boot drive after using an SSD is like night and day. As you said though, you didn't spend a lot of time with it. Perhaps the difference would have been more apparent if you had used the SSD for several days before switching back.
Good deal on the Agility, though. From what I've seen/read it is close to the Vertex...so you'll be getting similar performance for $100 less. Nothing wrong with that.
here's the link to the $140 deal
http://slickdeals.net/forums/showthread.php?t=1616337
yah, this might be the way I go as well...I am jonesing for an ssd, this might be a good place to start....
what others did you consider?
corsair?
kingston ?
supertalent?
thanks,
al
so,
just picked up this one....same as you.....
will let you know my how it works out.
OCZ OCZSSD2-1AGT60G Agility Series 60GB Solid State Drive
Hello, SSD! :p:p:p:p
Item Number: O261-6224
Model: OCZSSD2-1AGT60G
Availability: Order Today, Ships Today
Price: $181.99
Less Rebate: - $30.00
Final Price: $151.99*
The OCZ OCZSSD2-1AGT60G Agility Series 60GB Solid State Drive is the result of all the latest breakthroughs in SSD technology, including new architecture and controller design, blazing read/write speeds, and 64MB of onboard cache.
Specifications
Drive Type: Solid State Drive
Capacity: 60 GB
Interface: SATA
Write Speed: up to 135 MB/sec
Read Speed: up to 230 MB/sec
Form Factor: 2.5"
MTBF: 1,500,000 hrs.
Temperature, Operating (°C): 0 to 70
Dimensions: 3.93" x 2.74" x 0.37"
http://www.tigerdirect.com/applicat...ffiliateID=lw9MynSeamY-pFTk9db_Gnxb_mVfyXeFKw
..Once i got it i was impressed, but also not impressed at the same time, everything was much snappier of course, but it just was not worth $250 so i returned it. After i reinstalled my 6400aaks i was more unimpressed, it basically felt the same...
It's going to feel pretty similar if you aren't putting a heavy load on it. Drop a heavy workload (run a virus scan, install software, do a search, save a large document, open a large image that requires paging to disk) on the 6400aaks and the SSD and you'll feel a big difference when you hit the disk while its under load. SSDs remain responsive through almost anything, so you don't get those annoying lockups and stutters that platters have when they're busy.
If all you do is run word by itself, then yea... SSD isn't going to blow you away. If you have heavy disk activity at any point, SSD will blow you away.
well, will let you know if it makes a difference
getting mine today !
allen
its here!
now what do I do? hehehehe
will post up some stuff when I get it installed
allen
Mine comes in tomorrow, I know what to expect and for $150 AR it's worth it.
If you are running Windows 7 make sure to check the firmware or update to 1.4 with TRIM support. Here are my benchmarks before 1.4 firmware, and after 1.4 firmware:
CrystalDiskMark 2.2 (C) 2007-2008 hiyohiyo
Crystal Dew World : http://crystalmark.info/
Sequential Read : 169.700 MB/s
Sequential Write : 88.005 MB/s
Random Read 512KB : 134.187 MB/s
Random Write 512KB : 63.692 MB/s
Random Read 4KB : 26.838 MB/s
Random Write 4KB : 7.978 MB/s
Test Size : 100 MB
Date : 2009/10/28 1:45:53
Sequential Read : 158.395 MB/s
Sequential Write : 138.782 MB/s
Random Read 512KB : 163.487 MB/s
Random Write 512KB : 125.809 MB/s
Random Read 4KB : 26.867 MB/s
Random Write 4KB : 13.719 MB/s
Test Size : 100 MB
Date : 2009/10/28 2:21:10
yah, I did 183 shipped with 30 MIR
so about the same! it sure looks purhdy!
ahhahahaa
Test Size : 100 MB
Test Size : 100 MB
cool< how do I upgrade the firmware? what did you have to do?
allen
( oh, and just slammed 2gb -2- 1gb sticks- transcend into my AMD machine, about 5 yrs old..runs much faster, had 750gb)
So basically you "rented" it to try it out & returned it.
Thanks for raising the price for everyone else.
I'm waiting, as I have the feeling with Black Friday we will be seeing slightly better prices after rebate. Otherwise, $140 for this drive is a really cool price.
