- Dec 2, 2009
Ok so i bought the corsair h50. installed really easily.
i just had a couple of questions to make sure i did this right and im not gonna end up with a fried processor in a week.
I bought a 3pin to molex adapter and plugged the pump into one of the molex connectors.
i also already had a 120mm fan in the back, so i turned it around (so it blows air in) and left that fan plugged into one of the molex connectors.
will i be alright not having either the fan or the pump plugged into the mobo, so it can regulate the speed? (i.e. will they run at 100% all the time now)
my idle temps were from about 28C to 32C. i ran furmark for 1.30 minutes and heaven benchmark for 3 minutes (was in a hurry) and the highest the temps got was 36C. i know these temps are good but from your guys' experience, will these be consistent or will the temps increase the more i use the comp?
also when i over clock how high should temps of the processor be before i should worry and shut it down?
