Bottleneck Question.
I'm currently looking to upgrade my machine a bit and trying to figure out where I'll get the most performance upgrade for my money. Be it RAM, Video Card, processor (which might require a new MOBO so not sure I want to go that route.) I game mostly and while most things run fine, there are games I have to turn setting down on to run smoothly. Witcher 2 for example. I'm afraid I'll see similar situations arise with Skyrim and Arkham City as well. I run 2 dell monitors at 1900 X 1200 but one is just for web surfing and such.
My current system is as follows:
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core Processor BX80562Q6600
GIGABYTE GA-EP45-UD3R LGA 775 Intel P45 ATX Intel Motherboard
EVGA 896-P3-1260-AR GeForce GTX 260 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-4GBPK
I was thinking of jumping up to a Nvidia 560 but was unsure what kind of performance difference I would see between it and what I already have. I know a lot of sites are giving out a free copy of Arkham City with purchase of a new card which makes things more tempting. However, if simply getting more ram would help, it would be a cheaper option.
What do you guys think.
PS - Most of you here helped me build this PC and it's ran great so far. Thanks for everything you do here.
Generally speaking, the biggest gaming improvement will come from a GPU upgrade, assuming those games are more GPU limited than CPU limited. Though, I haven't kept up on the GPU scene, so I'll leave that suggestion to someone else. If you do have a nice budget for a new CPU/Mobo/RAM/GPU, then sell your old stuff and build anew! :p
Gaming
$250
North Carolina, Winston-Salem
Trying to figure out what small upgrade will help the most.
Not looking for a new build. Trying to find my weakest link
6) Will you be overclocking?
I don't have the proper cooling to do much OCing atm.
7) 7) What is the max resolution of your monitor? What size is it?
1900 X 1200
ASAP
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Still stock Danny. As for the PSU, I'm using:
OCZ ModXStream Pro 700W Modular High Performance Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341018
Can you OC that Q6600? An OC to about 3.2Ghz should help mitigate some of the bottlneck you'll see with a newer card. As for the PSU, not exactly a good choice but it's usable.
As far as new GPU goes, assuming no bottleneck, if you go with the GTX 560 TI, you're looking at 30% performance increase. So up to you if the 30% performance increase is worth the GTX 560 TI's cost.
