I doubt you'd ever get any recent flavor of Windows to boot properly or even install on a thumb drive but it's quite feasible w/Linux. Do a search, it's not at all uncommon.
Most motherboards made within the last 3 or 4 years will boot to a USB device. (See my Bootable USB drive howto in this subforum).
You could probably setup a windows installation on a USB flash drive, but it would kill your drive pretty fast with all the reads and writes. The flash memory used in USB flash drives is only writeable a few thousand cycles and after that you'll run into failures. Windows and all it's subsystems likes to do random reads and writes to the drive it's installed on and this will cause an early death to a flash memory device like that.
Most Windows installs run larger than 2gb or even 4gb anyway... 'Specially if you wanna do anything useful with it, I'm sure there's a few other reasons why it wouldn't be very feasible at all.
My mobo is an Intel D945PSN and has boot from USB capability. It is able to boot from USB based optical drives just fine but can't boot Windows from a USB based HDD. It BSODs on the Windows XP logo. Setup won't even see the drive on clean install.
