Boot Problems and More
Mcot
Ok here is my situation. I have a 500gb Sata Maxtor drive and a 120gb WD pata drive installed on my system.
I have successfully installed vista on the 500gb sata drive while I wait for my raptor x to come in. The pata drive is only in temporarily until I get the raptor.
The problem: On startup I get a message that HHDD0 is the Western Digital 120gb then it says hit a key to continue, but I don't have to hit a key and it just boots off the sata drive.
In BIOS the boot priority is HDD CDROM then Floppy, and the HDD priority is the SATA drive then the PATA drive. So I don't know why this message is coming up on startup.
Also, totally unrelated probably but who knows:
When I start the computer, it starts for like 2 seconds then shuts off, then 2 seconds later it starts up again and boots normally. Everything seems fine when it starts normally except for the above problem, but its just powering itself on and off real quick every time.
These problems aren't really affecting my system, and when it loads into windows its beautiful, very stable, but Id like to get these two annoyances fixed.
Unplug everything including hard drives and see if the power up problem goes away.
If it does go away, add the things back in one by one and find when it starts again.
This way you may find a faulty component or...
Its possible your PSU is getting overloaded.
If you get your machine stable with many things plugged in again, minus any components it doesnt seem to work with, try putting in some PCI cards/hard drives from another machine. If it starts being weird again, you know its very likely the PSU.
I think I have the WD pata set to cable select on the jumper, would that cause this problem???
Blech, don't use CS! I don't know why HDD makers even put that option on there, it causes nothing but problems most of the time. SATA and PATA don't like to play nice with each other in the first place. Set the PATA to master and see if that helps.
Often times, on an EIDE drive, "master" implies that a "slave" is present. Therefore, "cable select" or "single" is offered when there is only a single drive on the EIDE channel. I have numerous older systems using "cable select," and none of them have issues. It really depends on the drive and motherboard, which is why I asked what the other parts of the system were.
The CS setting on the drives is meant for use with a Cable Select IDE cable.
This cable has a hole punched in the Master/Slave wire going to the last IDE connector.
If you dont have one of those cables, the CS setting on the drives wont work properly when 2 drives are plugged onto the same cable.
You can fudge it by using Master or Slave jumper settings for one drive.
The idea is that if using a proper CS cable, selecting CS on both drives will automatically set the drives up to be master or slave depending on their position on the IDE cable.
On older systems CS may have provided a benefit, but it doesn't seem to be the case anymore.
The documentation on the EIDE drives I've owned state to set the jumper to "master" if using a single drive. Since OP only has one drive on the PATA channel, it's worth a shot.
The booting problem still exists, although I removed the pita pata drive.
I boot, it spins up the fans for ~4 seconds, powers completely off then restarts itself and boots perfectly fine.
This isn't really even causing me any troubles, but I would like to figure out what is causing it. Taking off all of the components one by one yielded nothing, it still did the same thing.
One thing that is abnormal is that it seems to be spinning up the fan very intensely on startup before it reboots, but the cpu temps are fine and the fan is connected correctly and the HS is mounted perfectly fine.
I'm stumped. Maybe a BIOS problem??? But I have the latest revision so IDK why this is happening.
which board? are you overclocking? plz list your other components in detail.
Abit IP-35E Motherboard
Intel e6750 at 3.2ghz (8x multiplier 400mhz fsb)
OCZ Commando ddr2 800mhz ram in a 1:1 ratio at stock voltage and timings
8800 GTS 320MB not overclocked
Maxtor (rebranded segate 7200.10 500gb drive)
Sata DVD RW
Rosewill 600w PSU
This was happening before I overclocked the processor so its not that.
I think this might be the problem but I have no way of knowing what is causing it....
From the PSU Manual
"2. Overload / Short Circuit Protection
The power supply is designed with overload protection and short circuit protection to prevent power supply components from damage. Main power shall latch into shutdown state within 50ms when over load or short circuit is applied. +5Vsb is designed as an auto recovery mode protection. Over load protection sense level as 110-160% of max load.
3.) Reset After Shut Down
If the main power latches into a shut down due to fault condition on output the power supply shall return to normal operation ONLY AFTER the fault has been removed and 'PS-ON' has been cycled off/ on with a minimum of time for 1 second. "
That Rosewill can't power your system with that 8800GTS in it. From evga's wesbite:
Minimum of a 400 Watt power supply.
(Minimum recommended power supply with +12 Volt current rating of 26 Amp Amps.)
That Rosewill PSU only has 21Amps on the +12V rail. You need 26Amps on the +12V rail for that 8800GTS. So you need to buy a new power supply. See if you can return that PSU for a refund or at least an exchange.
But it looks like you're gonna have to buy a new PSU. I recommend getting this PSU. It should support the 8800GTS pretty well:
XCLIO Goodpower 500W PSU - $50
No. The rating is for 1 12v rail. I have 2 12volt rails, so it has over the 26 amps needed, although it isnt quite 21*2 on the 12v rail, it is way more than 26 amps. I checked all of this out before I bought it.
Ahh made a mistake in my original calculations. Had divided 480W by 22 (from the max amps on the +12Vrail) rather than by 12 (From the 12V rail). So you should have a total of 40Amps for the +12V rail.
See if you can borrow a friend's power supply or a use a spare power supply to see if that Rosewill PSu is the problem. Like previously mentioned, Rosewill do make some bad PSUs.
I cannot figure this out. I did some cable management today so i was able to fish around in the case some more, and I cant find anywhere that looks like it is shorting out. All the components are fine and everything seems fine.
Would some misguided setting in BIOS cause this, or would it be stupid to go back and load the default BIOS settings....
The PSU seems fine. I have gamed, run orthos for long periods of time, and run some other stress testers with no abnormal signs of a bad PSU.
yah, go ahead and try resetting the bios to its defaults.
While the specs of that RD PSU may seem adequate, the quality of the unit is still questionable. It is made by Solytech... not a company known for reliable PSUs. Here's where I got the info. I realize the PSU in question on this post is not the same, but it is the same UL number on the newegg photo, therefore its the same OEM:
http://jonnyguru.com/forums/showpost.php?p=17205&postcount=4
Ok, this is really pissing me off.
Nothing in the BIOS fixes the problem, I tried almost every setting, and nothing worked.
I did however figure out that the problem goes like this:
Power On
case fans spin up
cpu fan spins up
GPU fan spins up and gets REAL LOUD
crash
4 second wait
restarts by itself perfectly fine
boots into windows
If I restart from windows:
restarts perfectly
Now I think the problem is with the GPU. I used 2 different PCI-E power cables and nothing changed
Updated the drivers for the card -- Nothing changed
Stress tested the GPU -- Works perfect.
And I cannot simply try a new PSU unless I RMA this one and order a new one, and I don't want to do that yet because it works perfectly except for this startup issue, and Im not even sure its the PSU.
None of my older PSU's have CPU or GPU power connectors.
