Gilthanis
[H]ard|DCer of the Year - 2014
- Jan 29, 2006
Yeah...sometimes BOINC will do that on the first connect. Glad it is up and running.
We are officially ending support for the following old versions of Windows:
Windows XP (64 bit ONLY)
Windows 2000
Windows NT
Windows ME
Windows 98
Windows 95
Windows for Workgroups
... and any version of Widows even older than those.
We are in the final testing stages testing the latest BOINC client in preperations for the use of the 7.2 BOINC client here at World Community Grid.
Although many of our volunteers are already doing it, we are interested in getting further testing and feedback.
For those of you who are interested in a preview, we ask that you download and install the current version offered from the BOINC website and proving feedback on your experience.
You can download the current version from here: http://boinc.berkeley.edu/dl/boinc_7.2.42_windows_intelx86.exe
Thanks for your help and assistance!
That all depends on which project you choose. Some are better than others. NFS for example (math project) doesn't use replication, so if you return a valid work unit, it is validated rather quickly. Little to zero redundancy.
Any idea when POEM wlll go full GPU availability?Good idea. I think probably the worst project at it is SETI. Those can sit waiting for validation for a very long time.
Dear philippe,
this project is not a single research project with one goal; in this project we can have several smaller (student) projects throughout the year. As it happens this week we will have some students running argon simulations on BOINC.
When a bigger research project is started and BOINC is used, it will be mentioned here. As it happens, it is not that easy to simply use BOINC for all our research, BOINC is just one of the many computational resources we have available. Also because BOINC (application) development is not for the faint harted, we tend to use the BOINC applications we already have running.
Currently we use BOINC for two things; one in teaching students; they run any type of classical trajectory they want whenever they want. As it happens this feature is open to the public too. Just look in your account on this project and see that you have a private 'queue' to submit Classical calculations into.
The other long term on going (pet) project of mine is investigating (rare) events in a specific water model. This project is a 'gather statistics and wait and see if the even happens' type of project; many many many runs are needed and the chances of any event happening are slim. To this end we continuously feed tasks into BOINC using the same input file over and over. Now due to a special trick we implemented in our application code, a random number generator seed is set and based on the work unit name. This will make sure that each individual run (although the input seems exactly the same) is an individual run. Once enough statistics are obtained we can conclude if this specific water model does feature rare events. If it doesn't, or it does wrongly so, we need to change the water model again and obviously start all over again. Now because this is a pet project me and the chances are slim to get any scientific publication in the sort-run about this, the work for this project is used as a feed when other sub project of Leiden Classical are not using BOINC.
Apart from all that, you do also need to know that this Leiden Classical thing is a sort of one man show; in our group I need to maintain and run this project on my own and I do have other stuff to do as well .
Hope to have informed you a bit.
If you want some more info you can have a look at http://theorchem.leidenuniv.nl
m.
_____
I've just updated the POEM@HOME Binaries to Version 2.00. This is the first big step for our new GPU project. I'll have to adjust some parameters of the new work units, and will send them out at the end of this week.
I'm confident the errors which occurred during the test phase have been resolved. If you encounter any problems nevertheless, please report it in our message boards.
Solo Collatz applications are now available for Android. The Android application supports ARM, x86, and MIPS (Little Endian) processors. Assuming Murphy's Law will prevail as usual even though the apps work on my hardware, please let me know of any issues.
I have found that people are still buying socket 775 boards on eBay. However, they don't sell for much. I have donated quite a few dual cores. So, if you can find a case in another junker, you may be able to get a donation or two out of them.
What are the combo specs?Also ended up with a few spare C2D board/CPU/RAM combos, not really sure what to do with them.
I might be interested in the CPUs and RAM to upgrade my Intel E5200 box.
