BOINC / SETI@Home question.
criccio
Fully Equipped
Any particular reason why it is only starting 3 instances and therefore only using 75% of my CPU?
What version Boinc are you using? (latest recommended version is 6.6.36) http://boinc.berkeley.edu/dl/?C=M;O=D
Be sure that under the Advanced/Preferences/process usage tab that process usage is set to 100%
Uninstall and reinstall Boinc, (don't install over the top) you will not loose your projects or work - this will let Boinc re-detect your hardware.
Do you have a quad core or an AMD x3?
Check your C:\ProgramData\BOINC\client_state.xml and C:\ProgramData\BOINC\client_state_prev.xml files and look for <p_ncpus>4</p_ncpus> about 10 lines down - be sure this is set to how many cores you have.
Is there a cc_config.xml file with a cpu limit line in your C:\ProgramData\BOINC\projects\setiathome.berkeley.edu directory? (Vista location - XP is elsewhere)
Its a Q6600, and everything else you said checks out. Guess I'll re-install. O well.
Maybe its got something to do with it also using CUDA at the same time? I don't know. My 8800GT's temps increase 15 degrees when its running so I know CUDA is working. It also starts a process called "setiathome_6.08_windows_intelx86_cuda.exe" but that only uses about 5 or 6% of the CPU according to the Task Manager.
And yes, I'm running 6.6.36.
Running a Cuda unit won't prevent you from crunching 4 cpu units on 4 cores.
You can run 4cpu+1cuda (with one video card) or 4cpu + how ever many video cards you have.
Re-installing sounds like is going to be your next best option. (be sure to do a un-install - re-install)
Good luck, let me know what you come up with.
Brother/Sister criccio brother Razor_FX_II is 100% accurate (as usual concerning anything to do with DCing ;)). Before I got into this summer time temperature situation I had two dedicated Q6600 G0's with low TDP GPU's crunching 24/7 (a 8800GS + a 9600GSO) On the boxen I shut down I was running GPU2 on a eVGA 9600GSO and the WCG clients at the same time, no problemos. On my remaining 24/7 DCer I run the GPU2 client (8800GS) and the F@H SMP clients (Q6600 G0) concurently. :)
I hope your reinstall works out. Reinstallation can be a PITA, but it's cured a many a prob :D
Well I installed last night and that didn't cure anything. Still only 3 CPU processes started up leaving my CPU chugging along at 75% usage. I just let it go overnight...
Woke up this morning and there is NO CPU processes going, only CUDA! What is going on?
Here is a part of the log till the presesnt (to large to post the whole thing):
Code:
6/14/2009 11:30:34 PM	SETI@home	Requesting new tasks for GPU
6/14/2009 11:30:36 PM	SETI@home	Started upload of 01mr09ab.2243.13569.11.8.124_1_0
6/14/2009 11:30:39 PM	SETI@home	Finished upload of 01mr09ab.2243.13569.11.8.124_1_0
6/14/2009 11:30:39 PM	SETI@home	Scheduler request completed: got 0 new tasks
6/14/2009 11:30:39 PM	SETI@home	Message from server: (Project has no jobs available)
6/14/2009 11:31:55 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:31:55 PM	SETI@home	Reporting 1 completed tasks, requesting new tasks for GPU
6/14/2009 11:32:00 PM	SETI@home	Scheduler request completed: got 0 new tasks
6/14/2009 11:32:00 PM	SETI@home	Message from server: (Project has no jobs available)
6/14/2009 11:32:15 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:32:15 PM	SETI@home	Requesting new tasks for GPU
6/14/2009 11:32:20 PM	SETI@home	Scheduler request completed: got 0 new tasks
6/14/2009 11:32:20 PM	SETI@home	Message from server: (Project has no jobs available)
6/14/2009 11:33:35 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:33:35 PM	SETI@home	Requesting new tasks for GPU
6/14/2009 11:33:40 PM	SETI@home	Scheduler request completed: got 1 new tasks
6/14/2009 11:33:42 PM	SETI@home	Started download of 01mr09ad.13160.14387.5.8.17
6/14/2009 11:33:45 PM	SETI@home	Finished download of 01mr09ad.13160.14387.5.8.17
6/14/2009 11:33:56 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:33:56 PM	SETI@home	Requesting new tasks for GPU
6/14/2009 11:34:01 PM	SETI@home	Scheduler request completed: got 0 new tasks
6/14/2009 11:34:01 PM	SETI@home	Message from server: (Project has no jobs available)
6/14/2009 11:35:16 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:35:16 PM	SETI@home	Requesting new tasks for GPU
6/14/2009 11:35:21 PM	SETI@home	Scheduler request completed: got 0 new tasks
6/14/2009 11:35:21 PM	SETI@home	Message from server: (Project has no jobs available)
6/14/2009 11:37:36 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:37:36 PM	SETI@home	Requesting new tasks for GPU
6/14/2009 11:37:41 PM	SETI@home	Scheduler request completed: got 1 new tasks
6/14/2009 11:37:43 PM	SETI@home	Started download of 01mr09ad.13160.16023.5.8.187
6/14/2009 11:37:46 PM	SETI@home	Finished download of 01mr09ad.13160.16023.5.8.187
6/14/2009 11:37:57 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:37:57 PM	SETI@home	Requesting new tasks for GPU
6/14/2009 11:38:02 PM	SETI@home	Scheduler request completed: got 0 new tasks
6/14/2009 11:38:02 PM	SETI@home	Message from server: (Project has no jobs available)
6/14/2009 11:39:17 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:39:17 PM	SETI@home	Requesting new tasks for CPU
6/14/2009 11:39:22 PM	SETI@home	Scheduler request completed: got 0 new tasks
6/14/2009 11:39:22 PM	SETI@home	Message from server: (Project has no jobs available)
6/14/2009 11:39:38 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:39:38 PM	SETI@home	Requesting new tasks for GPU
6/14/2009 11:39:43 PM	SETI@home	Scheduler request completed: got 0 new tasks
6/14/2009 11:39:43 PM	SETI@home	Message from server: (Project has no jobs available)
6/14/2009 11:41:58 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:41:58 PM	SETI@home	Requesting new tasks for GPU
6/14/2009 11:42:03 PM	SETI@home	Scheduler request completed: got 0 new tasks
6/14/2009 11:42:03 PM	SETI@home	Message from server: (Project has no jobs available)
6/14/2009 11:43:18 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:43:18 PM	SETI@home	Requesting new tasks for GPU
6/14/2009 11:43:23 PM	SETI@home	Scheduler request completed: got 0 new tasks
6/14/2009 11:43:23 PM	SETI@home	Message from server: (Project has no jobs available)
6/14/2009 11:43:38 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:43:38 PM	SETI@home	Requesting new tasks for CPU
6/14/2009 11:43:43 PM	SETI@home	Scheduler request completed: got 0 new tasks
6/14/2009 11:43:43 PM	SETI@home	Message from server: (Project has no jobs available)
6/14/2009 11:49:59 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:49:59 PM	SETI@home	Requesting new tasks for GPU
6/14/2009 11:50:04 PM	SETI@home	Scheduler request completed: got 0 new tasks
6/14/2009 11:50:04 PM	SETI@home	Message from server: (Project has no jobs available)
6/14/2009 11:50:11 PM	SETI@home	Computation for task 01mr09ab.2243.13569.11.8.127_0 finished
6/14/2009 11:50:11 PM	SETI@home	Starting 01mr09ab.2243.13569.11.8.111_0
6/14/2009 11:50:11 PM	SETI@home	Starting task 01mr09ab.2243.13569.11.8.111_0 using setiathome_enhanced version 608
6/14/2009 11:50:13 PM	SETI@home	Started upload of 01mr09ab.2243.13569.11.8.127_0_0
6/14/2009 11:50:17 PM	SETI@home	Finished upload of 01mr09ab.2243.13569.11.8.127_0_0
6/14/2009 11:50:19 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:50:19 PM	SETI@home	Reporting 1 completed tasks, requesting new tasks for GPU
6/14/2009 11:50:24 PM	SETI@home	Scheduler request completed: got 0 new tasks
6/14/2009 11:50:24 PM	SETI@home	Message from server: (Project has no jobs available)
6/14/2009 11:51:39 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:51:39 PM	SETI@home	Requesting new tasks for GPU
6/14/2009 11:51:44 PM	SETI@home	Scheduler request completed: got 0 new tasks
6/14/2009 11:51:44 PM	SETI@home	Message from server: (Project has no jobs available)
6/14/2009 11:52:20 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:52:20 PM	SETI@home	Requesting new tasks for GPU
6/14/2009 11:52:25 PM	SETI@home	Scheduler request completed: got 1 new tasks
6/14/2009 11:52:27 PM	SETI@home	Started download of 01mr09ad.13160.21340.5.8.59
6/14/2009 11:52:30 PM	SETI@home	Finished download of 01mr09ad.13160.21340.5.8.59
6/14/2009 11:52:40 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:52:40 PM	SETI@home	Requesting new tasks for GPU
6/14/2009 11:52:45 PM	SETI@home	Scheduler request completed: got 0 new tasks
6/14/2009 11:52:45 PM	SETI@home	Message from server: (Project has no jobs available)
6/14/2009 11:54:00 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:54:00 PM	SETI@home	Requesting new tasks for GPU
6/14/2009 11:54:05 PM	SETI@home	Scheduler request completed: got 0 new tasks
6/14/2009 11:54:05 PM	SETI@home	Message from server: (Project has no jobs available)
6/14/2009 11:55:20 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:55:20 PM	SETI@home	Requesting new tasks for GPU
6/14/2009 11:55:25 PM	SETI@home	Scheduler request completed: got 0 new tasks
6/14/2009 11:55:25 PM	SETI@home	Message from server: (Project has no jobs available)
6/14/2009 11:55:40 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:55:40 PM	SETI@home	Requesting new tasks for GPU
6/14/2009 11:55:45 PM	SETI@home	Scheduler request completed: got 0 new tasks
6/14/2009 11:55:45 PM	SETI@home	Message from server: (Project has no jobs available)
6/14/2009 11:57:23 PM	SETI@home	Restarting task 01mr09ab.2243.13569.11.8.111_0 using setiathome_enhanced version 608
6/14/2009 11:59:01 PM	SETI@home	Sending scheduler request: To fetch work.
6/14/2009 11:59:01 PM	SETI@home	Requesting new tasks for GPU
6/14/2009 11:59:06 PM	SETI@home	Scheduler request completed: got 0 new tasks
6/14/2009 11:59:06 PM	SETI@home	Message from server: (Project has no jobs available)
6/15/2009 12:06:22 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 12:06:22 AM	SETI@home	Requesting new tasks for GPU
6/15/2009 12:06:27 AM	SETI@home	Scheduler request completed: got 0 new tasks
6/15/2009 12:06:27 AM	SETI@home	Message from server: (Project has no jobs available)
6/15/2009 12:33:44 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 12:33:44 AM	SETI@home	Requesting new tasks for GPU
6/15/2009 12:33:49 AM	SETI@home	Scheduler request completed: got 0 new tasks
6/15/2009 12:33:49 AM	SETI@home	Message from server: (Project has no jobs available)
6/15/2009 12:36:35 AM	SETI@home	Computation for task 01mr09ab.2243.8661.11.8.56_0 finished
6/15/2009 12:36:35 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 12:36:35 AM	SETI@home	Requesting new tasks for CPU
6/15/2009 12:36:37 AM	SETI@home	Started upload of 01mr09ab.2243.8661.11.8.56_0_0
6/15/2009 12:36:40 AM	SETI@home	Finished upload of 01mr09ab.2243.8661.11.8.56_0_0
6/15/2009 12:36:40 AM	SETI@home	Scheduler request completed: got 0 new tasks
6/15/2009 12:36:40 AM	SETI@home	Message from server: (Project has no jobs available)
6/15/2009 12:37:55 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 12:37:55 AM	SETI@home	Reporting 1 completed tasks, requesting new tasks for CPU
6/15/2009 12:38:00 AM	SETI@home	Scheduler request completed: got 0 new tasks
6/15/2009 12:38:00 AM	SETI@home	Message from server: (Project has no jobs available)
6/15/2009 12:39:15 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 12:39:15 AM	SETI@home	Requesting new tasks for CPU
6/15/2009 12:39:20 AM	SETI@home	Scheduler request completed: got 0 new tasks
6/15/2009 12:39:20 AM	SETI@home	Message from server: (Project has no jobs available)
6/15/2009 12:40:35 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 12:40:35 AM	SETI@home	Requesting new tasks for CPU
6/15/2009 12:40:45 AM	SETI@home	Scheduler request completed: got 0 new tasks
6/15/2009 12:40:45 AM	SETI@home	Message from server: (Project has no jobs available)
6/15/2009 12:46:01 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 12:46:01 AM	SETI@home	Requesting new tasks for CPU
6/15/2009 12:46:06 AM	SETI@home	Scheduler request completed: got 0 new tasks
6/15/2009 12:46:06 AM	SETI@home	Message from server: (Project has no jobs available)
6/15/2009 12:52:28 AM	SETI@home	Computation for task 01mr09ab.2243.20931.11.8.247_0 finished
6/15/2009 12:52:29 AM	SETI@home	Computation for task 01mr09ab.2243.20931.11.8.235_0 finished
6/15/2009 12:52:30 AM	SETI@home	Started upload of 01mr09ab.2243.20931.11.8.247_0_0
6/15/2009 12:52:31 AM	SETI@home	Started upload of 01mr09ab.2243.20931.11.8.235_0_0
6/15/2009 12:52:32 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 12:52:32 AM	SETI@home	Requesting new tasks for CPU
6/15/2009 12:52:34 AM	SETI@home	Finished upload of 01mr09ab.2243.20931.11.8.247_0_0
6/15/2009 12:52:34 AM	SETI@home	Finished upload of 01mr09ab.2243.20931.11.8.235_0_0
6/15/2009 12:52:37 AM	SETI@home	Scheduler request completed: got 0 new tasks
6/15/2009 12:52:37 AM	SETI@home	Message from server: (Project has no jobs available)
6/15/2009 12:52:52 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 12:52:52 AM	SETI@home	Reporting 2 completed tasks, requesting new tasks for CPU
6/15/2009 12:52:57 AM	SETI@home	Scheduler request completed: got 0 new tasks
6/15/2009 12:52:57 AM	SETI@home	Message from server: (Project has no jobs available)
6/15/2009 12:55:12 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 12:55:12 AM	SETI@home	Requesting new tasks for CPU
6/15/2009 12:55:17 AM	SETI@home	Scheduler request completed: got 0 new tasks
6/15/2009 12:55:17 AM	SETI@home	Message from server: (Project has no jobs available)
6/15/2009 12:59:33 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 12:59:33 AM	SETI@home	Requesting new tasks for CPU
6/15/2009 12:59:38 AM	SETI@home	Scheduler request completed: got 0 new tasks
6/15/2009 12:59:38 AM	SETI@home	Message from server: (Project has no jobs available)
6/15/2009 1:01:53 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 1:01:53 AM	SETI@home	Requesting new tasks for CPU
6/15/2009 1:01:58 AM	SETI@home	Scheduler request completed: got 0 new tasks
6/15/2009 1:01:58 AM	SETI@home	Message from server: (Project has no jobs available)
6/15/2009 1:03:13 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 1:03:13 AM	SETI@home	Requesting new tasks for GPU
6/15/2009 1:03:18 AM	SETI@home	Scheduler request completed: got 0 new tasks
6/15/2009 1:03:18 AM	SETI@home	Message from server: (Project has no jobs available)
6/15/2009 1:04:33 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 1:04:33 AM	SETI@home	Requesting new tasks for CPU
6/15/2009 1:04:38 AM	SETI@home	Scheduler request completed: got 0 new tasks
6/15/2009 1:04:38 AM	SETI@home	Message from server: (Project has no jobs available)
6/15/2009 1:30:55 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 1:30:55 AM	SETI@home	Requesting new tasks for CPU
6/15/2009 1:31:00 AM	SETI@home	Scheduler request completed: got 0 new tasks
6/15/2009 1:31:00 AM	SETI@home	Message from server: (Project has no jobs available)
6/15/2009 2:02:17 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 2:02:17 AM	SETI@home	Requesting new tasks for CPU
6/15/2009 2:02:39 AM		Project communication failed: attempting access to reference site
6/15/2009 2:02:40 AM		Internet access OK - project servers may be temporarily down.
6/15/2009 2:02:42 AM	SETI@home	Scheduler request failed: Couldn't connect to server
6/15/2009 2:03:42 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 2:03:42 AM	SETI@home	Requesting new tasks for CPU
6/15/2009 2:04:04 AM		Project communication failed: attempting access to reference site
6/15/2009 2:04:05 AM		Internet access OK - project servers may be temporarily down.
6/15/2009 2:04:07 AM	SETI@home	Scheduler request failed: Couldn't connect to server
6/15/2009 2:05:07 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 2:05:07 AM	SETI@home	Requesting new tasks for CPU
6/15/2009 2:05:29 AM		Project communication failed: attempting access to reference site
6/15/2009 2:05:30 AM		Internet access OK - project servers may be temporarily down.
6/15/2009 2:05:32 AM	SETI@home	Scheduler request failed: Couldn't connect to server
6/15/2009 2:06:32 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 2:06:32 AM	SETI@home	Requesting new tasks for CPU
6/15/2009 2:06:54 AM		Project communication failed: attempting access to reference site
6/15/2009 2:06:55 AM		Internet access OK - project servers may be temporarily down.
6/15/2009 2:06:57 AM	SETI@home	Scheduler request failed: Couldn't connect to server
6/15/2009 2:07:57 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 2:07:57 AM	SETI@home	Requesting new tasks for CPU
6/15/2009 2:08:22 AM	SETI@home	Scheduler request completed: got 0 new tasks
6/15/2009 2:08:22 AM	SETI@home	Message from server: (Project has no jobs available)
6/15/2009 2:56:39 AM	SETI@home	Computation for task 01mr09ab.2243.13569.11.8.111_0 finished
6/15/2009 2:56:39 AM	SETI@home	Starting 01mr09ab.2243.13569.11.8.122_1
6/15/2009 2:56:39 AM	SETI@home	Starting task 01mr09ab.2243.13569.11.8.122_1 using setiathome_enhanced version 608
6/15/2009 2:56:41 AM	SETI@home	Started upload of 01mr09ab.2243.13569.11.8.111_0_0
6/15/2009 2:56:44 AM	SETI@home	Finished upload of 01mr09ab.2243.13569.11.8.111_0_0
6/15/2009 3:34:43 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 3:34:43 AM	SETI@home	Reporting 1 completed tasks, requesting new tasks for CPU
6/15/2009 3:34:48 AM	SETI@home	Scheduler request completed: got 0 new tasks
6/15/2009 3:34:48 AM	SETI@home	Message from server: (Project has no jobs available)
6/15/2009 6:04:36 AM	SETI@home	Computation for task 01mr09ab.2243.13569.11.8.122_1 finished
6/15/2009 6:04:36 AM	SETI@home	Starting 01mr09ab.2243.13569.11.8.113_1
6/15/2009 6:04:36 AM	SETI@home	Starting task 01mr09ab.2243.13569.11.8.113_1 using setiathome_enhanced version 608
6/15/2009 6:04:38 AM	SETI@home	Started upload of 01mr09ab.2243.13569.11.8.122_1_0
6/15/2009 6:04:41 AM	SETI@home	Finished upload of 01mr09ab.2243.13569.11.8.122_1_0
6/15/2009 7:03:41 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 7:03:41 AM	SETI@home	Reporting 1 completed tasks, requesting new tasks for CPU
6/15/2009 7:03:46 AM	SETI@home	Scheduler request completed: got 0 new tasks
6/15/2009 7:03:46 AM	SETI@home	Message from server: (Project has no jobs available)
6/15/2009 9:12:02 AM	SETI@home	Computation for task 01mr09ab.2243.13569.11.8.113_1 finished
6/15/2009 9:12:02 AM	SETI@home	Starting 01mr09ab.2243.13569.11.8.116_1
6/15/2009 9:12:02 AM	SETI@home	Starting task 01mr09ab.2243.13569.11.8.116_1 using setiathome_enhanced version 608
6/15/2009 9:12:04 AM	SETI@home	Started upload of 01mr09ab.2243.13569.11.8.113_1_0
6/15/2009 9:12:08 AM	SETI@home	Finished upload of 01mr09ab.2243.13569.11.8.113_1_0
6/15/2009 10:22:08 AM	SETI@home	Sending scheduler request: To fetch work.
6/15/2009 10:22:08 AM	SETI@home	Reporting 1 completed tasks, requesting new tasks for CPU
6/15/2009 10:22:13 AM	SETI@home	Scheduler request completed: got 0 new tasks
6/15/2009 10:22:13 AM	SETI@home	Message from server: (Project has no jobs available)
6/15/2009 11:16:05 AM		No general preferences found - using BOINC defaults
6/15/2009 11:16:05 AM		Reading preferences override file
6/15/2009 11:16:05 AM		Preferences limit memory usage when active to 2047.24MB
6/15/2009 11:16:05 AM		Preferences limit memory usage when idle to 3685.04MB
6/15/2009 11:16:05 AM		Preferences limit disk usage to 10.00GB
6/15/2009 11:19:18 AM		No general preferences found - using BOINC defaults
6/15/2009 11:19:18 AM		Reading preferences override file
6/15/2009 11:19:18 AM		Preferences limit memory usage when active to 2047.24MB
6/15/2009 11:19:18 AM		Preferences limit memory usage when idle to 3685.04MB
6/15/2009 11:19:18 AM		Preferences limit disk usage to 10.00GB
6/15/2009 11:19:19 AM	SETI@home	Restarting task 01mr09ab.2243.13569.11.8.116_1 using setiathome_enhanced version 608
6/15/2009 11:23:21 AM	SETI@home	Computation for task 01mr09ab.2243.13569.11.8.116_1 finished
6/15/2009 11:23:21 AM	SETI@home	Starting 21mr09ad.26949.139603.10.8.154_2
6/15/2009 11:23:21 AM	SETI@home	Starting task 21mr09ad.26949.139603.10.8.154_2 using setiathome_enhanced version 608
6/15/2009 11:23:23 AM	SETI@home	Started upload of 01mr09ab.2243.13569.11.8.116_1_0
6/15/2009 11:23:27 AM	SETI@home	Finished upload of 01mr09ab.2243.13569.11.8.116_1_0
Well going by that screenshot, you don't have any CPU work to crunch. Make sure your preferences are set right at the SETI@Home website. And make sure that BOINC Manager is set to get more then the default .25 days worth of work.
You haven't downloaded any for some reason. Make sure you have the BOINC manager set to hold like 3 days of work and make sure you have your SETI preference set to crunch both CPU and GPU. I would also look into running the optimized apps.
Well I changed the Additional Work Buffer to 3 days and hit update in the BOINC client, we'll see what happens.
EDIT
It downloaded a ton more CUDA work, nothing for the CPU though....
I have seen these optimized clients mentioned, but there seems to be a few, with no clear place for me to find out which one to run. Will any of them allow me to use the CPU and GPU at the same time? Are any of them as easy to use as the official?
From your log file:
Code:
It sounds to me like they just aren't releasing CPU jobs right now?
Did you check your SETI@Home preferences? If so how are they set?
I went through every setting again and again and it all looks to be correct. At this point I'm just going to let it be for a few days and see what happens.
Posted via [H] Mobile Device
Well I joined Einstein@Home and that started 4 threads perfectly fine and SETI@Home is taking care of the GPU.
I had that same problem and just gave up trying to get all 4 cores and Cuda running at all times. Sometimes it would work but most of the time it acted like no work available. As soon as I changed my settings to not use Cuda, I got CPU work with no probs. Then, I activated Cuda again. Sometimes it would give me Cuda work again and sometimes it stuck to just CPU work. I think their system is just buggy. Choosing Einstein was a good idea. I have less problems running Cuda and 4 cores when I have other projects to support. Einstein is also working on a Cuda app, so later you can use it there too.
