Helped my BIL setup an HTPC on his HDTV. It's a 60" Panasonic, with the HTPC connected through HDMI. Video looks fine, along with the desktop, but text is slightly pixelated around the edges. I've made sure it's running at 1080p resolution, and the TV is setup for game mode (there doesn't seem to be any specific options for 1:1 pixel mapping though.) I've also gone through different TrueType configs and all to no avail. You can't really notice it when sitting on the couch, but any closer and you will or if you're zoomed in on something.
I remember having a similar problem on my own HTPC setup at home. My LG 24" monitor has an HDMI input, so it came with a DVI-HDMI cable and of course looks perfect. When I tried it out on my HDTV though, same problem. I ended up "solving" the problem by using the VGA port on the TV and the audio through the 3.5mm speaker jack, and BOOM pixel perfect text & images. Problem is, his TV only has HDMI inputs (which I think is bogus, for such a nice expensive TV.)
I can get more specifics later, such as the model # and hardware (I remember it's an nVidia with the latest WHQL drivers) as well as a couple close up pictures of the problem if that would help.
