I'm iced in here in OKC, so it must be time to order parts for an HTPC!
Basically, the goal of this build is that I want a Blu-ray player with the ability to stream 720p over my wireless network, or watch hulu. It will be attached to my 720p TV, through HDMI, and hooked into my 5.1 surround sound.
I'm looking to spend as little as possible, while still being able to play 720p (of any of the common compressions) and blu-ray flawlessly.
Sort of a secondary goal is to keep it quiet. It's going to be in a little stand that should block most of the noise, but if I could passively cool the cpu, that would be an extra bonus. Willing to underclock, as long as it still plays flawlessly. Performance > Noise.
I've got a quiet seagate HD that I'm reusing, but everything else needs to be new. Also, I've had 5 unfortunate recent experiences with rebates in a row, so I'm refusing to mess with them this time around.
I've got access to Vista Enterprise (32 or 64), or I have a loose copy of XP 32-bit. I'm running Vista 64 on my machines right now, but whichever will give me the best performance (my guess is XP?) I'll install. I'm experienced with a couple linux flavors as well, enough so that I'm pretty sure I want to stick to Windows for this machine.
Here's what I have so far:
Foxconn A7GM-S AM2+/AM2 AMD 780G HDMI Micro ATX AMD Motherboard
ARCTIC COOLING ACF64LP 60mm CPU Cooler for low profile PC
Rosewill R379-SM Black/ Silver 0.8mm SGCC Steel MicroATX Slim Case Computer Case PSU ATX12V Flex 300W Power Supply
Kingston 2GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory Model KVR800D2N6/2G
Logitech EX 110 Black USB + PS/2 Standard Cordless Desktop Keyboard & Mouse Kit
ENCORE ENLWI-N PCI 2.3 Wireless Adapter
LITE-ON Black 4X Blu-ray DVD-ROM SATA Model DH-4O1S-66
AMD Athlon X2 BE-2350 Brisbane 2.1GHz Socket AM2 45W Dual-Core Processor Model ADH2350IAA5DO
SUPER TALENT INTAIN1MCR All-in-one Card Reader
My worries are -
Will that Blu-ray drive having no cache be an issue? I plan on never reading a data Blu-ray disc, only movies.
Are there any better heatsinks out there for <$20 that could do the job quieter or passively?
Thanks in advance!
My worries are -
Thanks in advance!
