BlueIris NVR build
antok86
Running Blue Iris SOftware to record IP cameras
300-400?
US- FLORIDA
ram, cpu, case, mobo, psu, case
i have a 320gb 640gb 2.5 sata and a 3.5 4tb WD enterprise sata drive
6) Will you be overclocking?
no
plan to run headless.
asap
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
usb incase for external hard drive
windows 7 32 & 64 versions
looking to upgrade my IP camera setup and run Blue Iris software. looking for something in small footprint and not putting out too much heat while being able to do the recordings of ip cameras. Unit would be ran headless and run 24/7. it would be recording two local cameras and at least 1 over the internet. not sure where to start yet..looking to bounce some ideas
All right, here's what I recommend:
$68 - Intel Pentium G860 CPU
$90 - AsRock B75M-ITX Intel H61 mITX Intel Motherboard
$60 - Corsair CMV8GX3M1A1333C9 8GB DDR3 1333 RAM
$110 - Silverstone SG05B-USB3.0 mITX Case with FSP SFX 300W PSU
Total: $328 shipped
Total: $328 shipped
thanks dude! i will look at this a little bit more later. im looking at
https://loneindustries.com/ L1 case and running it with a picu psu. it seems to be the smallest case i can do with a mini itx motherboard. i might have to go a little higher in budget.
Looks like a nice case but $95 for that? Seems a bit much.
