Bluegears?
Search is your buddy ;)
The last 10 pages has a decent amount of user feedback.
Seems like minimal issues, above average sound quality, workable bass management (compared to the others that is) and DD encoding.
I'd still research it so you're comfortable with your decision
I'd probably recommend it if you intend on using it with a home theater receiver.
Do you mean Xoxide or bluegears? Both reputable in my experience. I've ordered stuff from xoxide with no problems (although their prices on some things are high), and heard positive reviews of the mystique.
