Blue Screen from hardware issues
ToddW2
I plug in USB flash card reader and I get a blue screen, happened twice in a row even after a reboot... same USB port.
I used the port under it, no problems.
Could it be the Mobo or case shorting out the mobo? I figure if it's the reader it would do it on the other ports too and/or not work or fry the memory card... all of which work fine.
I have never seen this before, but I don't think it's WIndows this time :confused:
Connect a different USB device to that "suspect" USB port.
Also what motherboard?
1st time ever I purchased a cheap motherboard, ASROCK B85M-ITX LGA1150
Tried a jump drive, it didn't have any issues. Tried to charge my GoPro, no issues.
Looks like it was the card-reader after-all... chucked that in the trash.
This is the 2nd Anker USB product I've had screw-up. 2 failures out of about 8 devices, a bit high for my liking :(
