Blue Screen/Freezing issue
iRpilot
Hey guys,
I've been having quite a few issues with my recent HTPC build and I would appreciate a little help or suggestions. For now I want to focus on my main problem:
After watching TV for a while (2+ hours) the picture will freeze for 10 seconds or so, the computer is unresponsive, and then I get the dreaded "Blue Screen".
It just randomly started happening, and I have been making so many changes to the settings and adding so much software to make everything work that it's impossible to narrow the problem down to one of those changes.
I've put so much time into making everything work right that I'm trying to avoid a reformat and starting from scratch. Also, if it does come to that, does anyone have any suggestions on an alternative to Windows Media Center for Live TV, Recording, and everything?
Any suggestions would be appreciated, Thanks guys!
Specs:
HTPC:
OS- Win7 x64 WMC
Mobo- Foxconn H67S
CPU- Core i3 2105
GPU- Intel HD 3000
RAM- 2 x 2GB DDR3 1333 Mushkin
Boot HDD- 60GB Corsair Force 3
Recording HDD- Seagate 5400.6 320gb 2.5"
Tuner- Ceton InfiniTV 4 PCIe
PSU- PicoPSU 150, 120 watt brick
Case- Wesena ITX7
Well, what does the BSOD say?
What case and PSU are you using?
Do you have the latest firmware for your SSD?
I thought the BSOD was just a general message, I wasn't sure if the numbers in it were specific to the problem. I will note the message next time it happens.
I'm using a Wesena ITX7 case, and a picoPSU 150 with a 120 watt brick, I'll update the OP.
I'll have to research my firmware on the SSD and let you know, and update it as needed.
Thanks.
