Do Not rule this out! Happens with my DVD player all the time. If one of them comes loose, or it's not set right in the menu, It gets FUBAR'ed.H-street said:just out of left field, have you double check your Yr Gr Br setup?
usually when i use my component out, you get a "Color" haze if you mixed up 2 of the inputs..
also make sure there isn't something you have to "enable" for the YGB output.. (although if i remember there wasn't, but double check)..
