Blackmagic Ultrascope Build
notsane
This is a build for a TV Studio Controlroom. It is a dedicated machine to run this high definition scope hardware/software. The system requirements page is out of date so I have sent my componenet list to them to look over.
Looking at the PCIe version (NOT Pocket Ultra Scope)
http://www.blackmagic-design.com/products/ultrascope/
Ultra Scope
2) What's your budget? Are tax and shipping included? Not limited, but don't want total overkill. Would like to leave enough headroom in the box for a little bit of future proofing.
3) Where do you live? Seattle
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
CPU, RAM, Mobo, DVD, HD, Case, PS, GPU
None
6) Will you be overclocking?
Unlikely
19x10 (or 19x12)
Now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Nothing Special
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Yes, either W7x64 or Vista x64
Please note that this list includeds a case that I don't want to use. I like the antec take 3 + 650 and plan to get that instead.
EVGA GeForce GTX 460 (Fermi) 768-P3-1360-TR Video Card
Item #:N82E16814130562 $179.99
GIGABYTE GA-P55-USB3 ATX Intel Motherboard
Item #:N82E16813128425 $119.99
LITE-ON 24X DVD Writer Black SATA Model iHAS424-98 LightScribe Support
Item #:N82E16827106335 $25.99
Intel Core i5-760 2.8GHz LGA 1156 95W Quad-Core Desktop Processor
Item #:N82E16819115067 $209.99
Antec 3U22EPS600 3U Rackmount Server Case
Item #:N82E16811129077 $299.99
Replace with Antec Take 3 + 650
Western Digital Caviar Blue 640GB 3.5" SATA 3.0Gb/s Internal Hard Drive -Bare Drive
Item #:N82E16822136218 $69.99
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory
Item #:N82E16820231193 $88.99
Grand Total: $994.93
http://www.blackmagic-design.com/support/detail.asp?techID=195
Get that mobo and CPU from this combo link to save $25:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.492250
Ditch that WD 640GB Blue drive: It's outperformed by these two drives:
$55 - Western Digital WD5000AAKS 500GB 7200RPM SATA 3.0Gb/s Hard Drive
$75 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
The HD 4870 1GB is well priced at $135 shipped:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121376
So that's a good alternative since that's on the official support list for Ultra Scope.
