By my math, I'm running at 40c idle in windows. That sound about right for an AC Pro 64 in a relatively cool room?
I'm asking because there isn't a monitoring program that reads the TA690G sensor right. Best I can get is one that reads 8-10c idle, so I'm doing math to try and get to what it should be.
What "math" are you doing to figure out your temperature readings?
temp = readout temp + how much it's off. I know abour what temp it is: Rebooting, the hw monitor in bios is accurate sounding. Just nothing in windows can read it right.
Biostar TA690G. Biostar USA doesn't admit the board exists.
keep in mind that the bios isn't an idle state, so you won't be getting an idle temp there. it's like 75% load or so from what i can tell![]()
Why isn't bios an idle state?
blech.
I'm done fighting with this. Going Intel. Anyone want one of these cheap?
blech.
blech.
you're going to intel just because you don't know for sure what the temp is?![]()
Running 3.0 Ghz at stock voltage (ignore sig, I just lowered it today) with 8 gigs of RAM on a mATX board. I'm curious as to the specs of your buddies' AMD rigs.
I'm using an Abit NF-M2 nView mATX board. I'm using Vista Ultimate 64. I really don't like AMD chipsets (we'll see about the upcoming release). Make sure you get all the hotfixes from Microshaft because I would initially crash until I got the hardware hotfixes.
KB938194
KB938979
KB929777
KB941649
I have the TF570 SLI mb and am looking for the latest BIOS with updates for the Black Edition cpu, but the Biostar page for the new BIOS N57IAB05.BST dated 11-14-2007 shows up 404 page not found.
Google doesn't show any other sources for the new BIOS. I wonder if anyone has copy they can email to me?
not sure. it just isn't
if you're trying to calculate your temps, just add 3/4 * difference to the idle temp, plus your offset to match the bios temp. it should be somewhat close![]()
Anyone get their hands on a 5200+ with 45w and oc it?
I can't seem to find how the amd 45w cpus overclock
