I have spent months on this problem and cannot solve it. A little while after I installed Windows 7, most games began to do a weird audio skip or pop. It's very consistent, you could almost keep a beat with how perfectly spaced they are. While it's mostly audio skips/pops/scratches the framerate seems to stall for a millisecond as well at the exact same time with each pop.
This happens ONLY in games. There has never been any issue with iTunes music or internet videos or anything else. I first noticed it in Mass Effect 1/2, then CODWAW, and even World of Warcraft. Some have suggested that my onboard audio could be causing the problem but I have found some people online with very similar problems who were using PCI audio cards I have reinstalled, updated, and repaired every driver or program imaginable. The only things I have read so far have been that it is possibly something with DirectX.
If you solve this, you will be officially crowned as COMPUTAR KINGZ.
Setup:
AMD Athlon 64 X2 5200+ 2.60GHZ
2GB DDR2
Gigabyte GA-M55SLI-S4 (rev. 1.0)
Sapphire Radeon HD 4830 512MB
Realtek 97 Onboard Audio
WD 160GB SATA
WD 80GB IDE
Windows 7 64-Bit
Oh yeah, and temps are completely where they should be. No overheating in terms of CPU or video card.
Thanks so much for your help everyone! Let me know if I forgot something!
Setup:
2GB DDR2
WD 160GB SATA
WD 80GB IDE
Windows 7 64-Bit
