Bizarre performance stuttering, need help troubleshooting...
JYeager11
Hi guys,
I have a stuttering issue with my computer that I've gotten so used to, it took someone else dropping by to point out to me how I really should look into fixing it for me to finally take steps to do so.
First, some info on the computer :
Windows 7 (Business) x64 Service Pack 1 (installed 2011-03-13)
5 x 2058 MB OCZ3P1333LV2G RAM (10 GB total)
PageFile Size : 10230 MB (In use : 1601 MB / Max used : 1895 MB)
System clock interval : 15 ms
Asus P6T Motherboard
Intel Core i7 CPU 920 @ 2.67 GHz (Socket 1366 LGA)
American Megatrends BIOS (1408)
NVIDIA GeForce GT 240 (512 MB) Driver 8.17.13.142 (2012-05-15)
Echo3G Sound Card
C:\ drive is a Crucial C300 SSD (128 GB)
Other drives : WD Caviar (1 TB) + WD Caviar (1 TB)
Symptoms : System appears to visually "freeze" for appx a second to a second and a half, every 18 seconds.
At first I thought it was just a video playback issue (because when videos would freeze, the audio would keep going without a problem). However, I noticed the locking up also happens when I type. Every 18 seconds, the typing on the screen freezes... then after the freeze it spits out everything I typed during that second, all at once. In other words, the computer's still listening to me while it appears frozen, it's not not showing me what I typed until the freeze is over.
Anyone have any idea what this could be?
NOTE: I tried leaving the task manager on and observing the running processes while things lock up, and nothing spikes up during those periods. Everything remains at 0, except Firefox which alternates between 1 and 3% activity (negligible).
Update the firmware on your SSD?
Update the BIOs on your mobo?
Do a fresh trial Windows 7 OS install on another HDD to rule out the SSD being the cause.
Try a different video card.
What PSU do you have?
I would very much like to update my BIOS, but American Megatrends is making me go through eSupport.com to get the update. eSupport.com is making me install and run BiosAgentPlus, which reports various areas where I could use an update (including the BIOS).
Upon clicking the download link to update the BIOS, I am sent to http://biosagentplus.com/join.php - which now wants me to sign up for a $30 service.
Is American Megatrends now charging for BIOS updates? Because it sure looks that way to me.
Can someone point me to FREE BIOS updates for my hardware?
Well thats something new: First time I've heard of someone actually going to the BIOs developers themselves for BIOs updates. You usually go to the motherboard manufacturer for BIOs updates. Anyway, just go to the Asus website for your mobo and download the BIOs update from there:
http://www.asus.com/Motherboards/Intel_Socket_1366/P6T/#download
Click the downloads tab, select your OS, and you'll see BIOs right there.
1408 (which I have) is the most recent one Asus is offering for the P6T / Win7-64. However, the automatic detection tool provided by the BIOS developers (which nobody but me goes to for updates, it seems) tells me my BIOS is out of date. And considering this BIOS is dated 2010, I'm inclined to believe it's true.
Where else can I get a BIOS update? Asus is too far behind.
Can't help you there. I usually just stick to the motherboard manufacturer.
Well, it appears updating the C300 SSD's firmware might've done the trick! 30 seconds into a video and no stuttering yet.
I had update 0006, and just updated to 0007.
Well it's been 3 1/2 hours since your last post. Still no more stuttering?
Well, I haven't been on much since my last post, but I'm not seeing any so far..! I didn't check out what firmware revision 0007 (of Crucial's C300 drive) actually fixes, but I wouldn't be surprised if stuttering was one of the issues addressed.
Thanks for suggesting I update this firmware. I'd already considered the BIOS, but not the SSD firmware.
